Turn Signals Dont Work....
Ok i searched but I want to see if anyone has any other suggestions. I recently swapped the dash out of my civic for a different civic dash and after i was done i had no signals. I didnt mess with anything on the steering wheel... I checked all my fuses, wires and bulbs and nothing they were all good... My hazards work and my hazard button is plugged in correctly, all my brakelights and headlights work, just no signals left or right. Do I just need to change the arm on the steering column or is this more of a wiring problem? Any suggestions or info would be greatly appreciated
check the under dash fuse panel for a loose harness, I had the ame problem with mine after I pulled the fusebox out to examine the area for any damage or wires, and forgot to plug on of the harnesses back in, i think it was the top right harness as you look at it, but anyways, same prob, hazards work because they are a independent circuit, but id chekc your fuse panel first for a loose harness.
yup probably the harness,check the wiring only for the signals threw the dealer see if they can give you the new dash wiring for signals,thats what i would do.
theyre right, check your fuse box for connections, check your relay, check your ground, and make sure your hazard switch is hooked up, cuz **** wont work if that aint pluged in.
ok i just went and checked and i didnt see any plugs that were disconnected? so a whole plug controls just the turn signals? my hazards work and everything else works as well, except the cluster blinkers and outside blinkers...
same thig happened to me ... well i was changing my cluster lights ... but what happened to me was i didnt have the hazard wireing clicked all the way in ...
i know you checked it already .. but take it out and reconnect it ...
hope everything works out ...
o yeah
did you mess with the wires other than whats nessisary for swapping the dash ?
o yeah
yeah i have unplugged and plugged in the hazard switch numerous times, and no i dont think that i messed with any other plugs besides whats necessary to swap dashes, besides i dont think an entire plug controls just the turn signals.. or does it?
yeah well if you ever get you signals working .. if you unplug the hazard lights the signals wont wont work ..
i had my hazard only half way in a only the left blinker went on
so maybe try cleaning the connections with some rubbing alchohall .. dont use to much though it will expletive ti up ...
get a q-tip and dip it in the bottle and clean the connections
this is as much as i know about this sorry i couldnt help more
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCJDM1 »</TD></TR><TR><TD CLASS="quote">yeah well if you ever get you signals working .. if you unplug the hazard lights the signals wont wont work ..
Ill go do that now, thanks alot for your help mang
