lowering question
Old Apr 26, 2002 | 03:29 PM
dust1's Avatar
Default lowering question
on a 98 civic ex 4dr....is it possible to lower my car with just springs, or would i have to also replace the struts and all, and end up spending more money then i want to...much less can...any help is greatly appreciated
[Modified by dust1, 12:30 AM 4/27/2002]
Old Apr 27, 2002 | 12:08 PM
94civicx's Avatar
New User
Default Re: lowering question (dust1)
you just need springs to lower your car and used the stock shocks. anything around 2" or lower should have an aftermarket shock. Try the neuspeed sport springs. lower the car approx 1.75" in the front and 1.5" in the rear
Old Apr 27, 2002 | 01:58 PM
-Gambit-'s Avatar
Default Re: lowering question (94civicx)
you can lower your car with just springs for a while but then your struts are going to wear out and blow then your car is going to bounce all over the place, so if you have the money you might as well change your struts too while your suspension is apart, so you dont have to take the time out to tear it all about again later
5800vtec
Apr 14, 2008 11:13 PM
SOLO1racer
20
Sep 7, 2007 08:03 AM
emegge
Suspension & Brakes
Feb 26, 2007 07:47 PM
dubxl152
11
Dec 17, 2002 05:18 AM
ngolimit408
Nov 4, 2002 07:31 AM
