throttle cord
Old Apr 26, 2002 | 03:25 PM
dust1's Avatar
Default throttle cord
hey guys, im having trouble locating my throttle cord, if someone cud send a pic or tell me how to recognize it, thatd be great, its a 98 civic ex 4dr...thnx for any help...
Old Apr 26, 2002 | 03:31 PM
infuryum's Avatar
Default Re:
Look at your engine. Find the intake manifold. Find the throttle body attached to it on the left side. On that, there's a cable that runs to the driver side of the car. That's your throttle cable.
Old May 9, 2002 | 12:45 PM
Muckman's Avatar
Moderator in Chief
Default Re: Re: (integral)
Ive heard of ppl tightening their throttle cable to ensure that the pedal to the floor is 100% throttle. How can I go out doing this?
Old May 9, 2002 | 02:23 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Re: (Muckman)
there's a nut on the throttle cable that you can raise/lower to lessen/increase the slack of the cable. the higher you raise the nut, the less slack you have, but watch your idle.
Old May 9, 2002 | 04:37 PM
Chiovnidca's Avatar
Default Re: Re: (dLo GSR)
Proper adjustment will leave 10mm fo slack.
Old May 9, 2002 | 07:09 PM
BreakStuff's Avatar
New User
Default Re: Re: (Chiovnidca)
and on automatic tranny's playing with this cable will also require an adjustment of the "trans throttle cable".. if you adjust one without the other, then please do wear your seatbelt.. you will need it so you don't bump yer head into the steering wheel when the car shifts gears..
Old May 9, 2002 | 07:15 PM
Redline130's Avatar
Default Re: Re: (BreakStuff)
I learned that the hard way
Sik Eg
Oct 21, 2012 04:39 PM
boostedteg1203
Jan 14, 2010 01:17 AM
NAallthewayEM1
12
Aug 1, 2009 08:41 PM
dustywebber
Jul 10, 2004 09:04 AM
