Suspension & Brakes Theory, alignment, spring rates....
Best ALL AROUND spring rate? GC coilovers...
Old Aug 24, 2006 | 06:02 PM
vg7z's Avatar
Default Best ALL AROUND spring rate? GC coilovers...
Im planning to order a set of GC coilovers with a custom spring rate. car is a 94 civic coupe, and is going to have a gsr turbo setup pushin 350whp. This car is going to bne my "weekend car", some drag, some auto x & canyon runs. What would be a good all around spring raet?
I was thinking 350F , 450R
Old Aug 24, 2006 | 08:06 PM
FalkenSiR's Avatar
Default Re: Best ALL AROUND spring rate? GC coilovers... (vg7z)
350 is waaay too soft for me at least. Next time I'll go with 400-450 F and the same for the rear.
Old Aug 27, 2006 | 06:09 PM
vg7z's Avatar
anyonme else?
Old Aug 27, 2006 | 06:41 PM
chrisw85's Avatar
i'm at 400F and 375R, i want to go a bit higher, maybe something like 450F and 475-500R.
it rides fine, but i feel the front is too soft and bottoming out on the most severe bumps. I'm not that low either. 5-3/8" measured at the front jack points, and 5-1/2" measured at the rear jack points.
but overall, i think 400/400 is a great starting point. the off the shelf rates are 380F and 280R, great for daily but to pushy (understeer) for track or autox.
Old Aug 27, 2006 | 07:23 PM
FalkenSiR's Avatar
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">
but overall, i think 400/400 is a great starting point. the off the shelf rates are 380F and 280R, great for daily but to pushy (understeer) for track or autox.</TD></TR></TABLE>
One of the main reasons I'm going stiffer next time
Old Aug 28, 2006 | 12:39 PM
vg7z's Avatar
hows 400/400 gonna do at the dragstruip? i herard somethign about having it a little stiffer in the rear to help with traction
Old Aug 28, 2006 | 12:55 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">i'm at 400F and 375R, i want to go a bit higher, maybe something like 450F and 475-500R.
I also started with 400/400 on Konis for my 00 gsr. Feels great on the street, but way too soft for autox and HPDEs. I also suffered from bottoming on the street.
Old Aug 28, 2006 | 01:41 PM
super_nguyen's Avatar
Default Re: (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">I also started with 400/400 on Konis for my 00 gsr. Feels great on the street, but way too soft for autox and HPDEs. I also suffered from bottoming on the street.</TD></TR></TABLE>
what shocks? if you have adjustable shocks like konis or AGX you can make them stiffer, i ride 350/400 and i never bottom out. unless you have some insane potholes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vg7z &raquo;</TD></TR><TR><TD CLASS="quote">hows 400/400 gonna do at the dragstruip? i herard somethign about having it a little stiffer in the rear to help with traction</TD></TR></TABLE>
for a FWD car you would want the rear to be as stiff as possible to keep the weight shift to a minimum becuase once you launch the weight shifts from the front to the back, meaning away from the drive wheels.
Old Aug 28, 2006 | 02:35 PM
TunerN00b's Avatar
Default Re: (super_nguyen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super_nguyen &raquo;</TD></TR><TR><TD CLASS="quote">what shocks? if you have adjustable shocks like konis or AGX you can make them stiffer, i ride 350/400 and i never bottom out. unless you have some insane potholes.
for a FWD car you would want the rear to be as stiff as possible to keep the weight shift to a minimum becuase once you launch the weight shifts from the front to the back, meaning away from the drive wheels.</TD></TR></TABLE>
Um, Konis adjust the rebound only, not the bump. So turning them up won't change how much the suspension moves under compression, just how fast it returns back afterwards. I never really had any issues bottoming with the stock UCAs in there (well, just once on a stupidly huge pothole), but with camber adjusters in there, they hit alot more often.
And its LA, I do have some insane potholes.
Old Aug 29, 2006 | 10:26 AM
vg7z's Avatar
if i was to get a 350F 500R, how would it handle? would it oversteer/understeer more?
Old Aug 29, 2006 | 05:42 PM
platinum00's Avatar
Default Re: (vg7z)
I run 350f / 450r with koni, and it feels great on the street.
I do run Suspension Techniques front and rear sways though.
platinum.
Old Aug 29, 2006 | 08:28 PM
hayabusa160's Avatar
Default Re: (platinum00)
380 front 430 rear it handles pretty good with a very slight push.
22mm front bar 23mm rear
anzai
Jun 26, 2011 10:28 AM
neverness
Honda S2000
Jul 18, 2006 04:40 PM
Blizzard
Suspension & Brakes
Jul 7, 2006 06:25 PM
b18crx
Nov 14, 2003 06:12 PM
combustion
Oct 23, 2003 05:50 AM
