climate control air speed 1 & 2 not working
you dont need a blower motor you need the blower motor resistor.. if your whole climate control doesnt work start by checking fuses with a test light.. if it works but doesnt light up that could just be the bulbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrPotatoeHead »</TD></TR><TR><TD CLASS="quote">NAH you need the blower motor switch. It can be had at like auto-zone.</TD></TR></TABLE>
How do you know its diffently the blower motor switch? It's more than likely the resistors. It needs to be checked first, then go replace parts.
It's the resistor that need to be replaced. I had the same problem before and I only replaced the resistor and it works again. Remove your glove box and you will see this, it's the one circled in yellow. My ride is RHD by the way.
bump! my whole climate control doesn't work. Any idea which fuse? i checked the majority of the fuses (a few are akward to check with what i got). My power mirror switch stopped working as well. Could they be connected?
also another question about the climate control, there must be one bulb that goes out every so often on the control, and i tap it, and it comes back on. how can i replace this bulb, its nothing serious just annoying
