no start, but cranks
Old Aug 24, 2006 | 04:21 PM
davin's Avatar
Default no start, but cranks
hey everyone, i just bought a 92 civic EG so i would stop putting miles on my FD3S. well, for some reason i got no spark. i replaced the rotor, cap and a new dizzy from autozone. one day i went to crank it and it fired right up, the next day it didnt start, but cranked like it did last time. then got a replacement dizzy from autozone and it would crank but not fireup again!
i am getting fuel preasure, the wires are in the correct spot and my cams turn but there is no spark. the dizzy is keyed correctly to the cam and this is the second dizzy where there is not spark. i am an aircraft mechanic for the navy, i am getting a degree in aerospace engineering and i work on my RX7 constantly, but this one has got me stumped... any ideas :-/
Old Aug 24, 2006 | 04:24 PM
davin's Avatar
Default Re: no start, but cranks (davin)
i also checked the battery and also jumped it just in case... no dice :-/
Old Aug 24, 2006 | 04:34 PM
davin's Avatar
i am also getting compression
Old Aug 24, 2006 | 04:35 PM
Archidictus's Avatar
Unceasing Measure
Have you tried borrowing a friend's ECU to see if that's the problem?
Old Aug 24, 2006 | 04:38 PM
davin's Avatar
Default Re: no start, but cranks (Archidictus)
no, i will do that. the only things i am thinking is...
1: the main relay
2: the wiring harness (but would this cause a no spark?)
3: a bad ground somewhere
4: a bad ECU
Old Aug 24, 2006 | 04:39 PM
davin's Avatar
BTW, where is the ECU on a 1992? i remember on my 98 is was on the passanger kick panel, but i cannot find htis one for the life of me.
Old Aug 24, 2006 | 04:41 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davin &raquo;</TD></TR><TR><TD CLASS="quote">BTW, where is the ECU on a 1992? i remember on my 98 is was on the passanger kick panel, but i cannot find htis one for the life of me.</TD></TR></TABLE>
Same place. Look harder
Old Aug 24, 2006 | 05:50 PM
instrument's Avatar
maybe you have no ecu........
omg
Old Aug 24, 2006 | 06:21 PM
Quarter Performance's Avatar
Default Re: (instrument)
yea, look at your grounds. i had a bad ground connection and car wouldnt start either. had compression and cranked over just woouldnt fire, fixed loose ground started right up.
Old Aug 24, 2006 | 06:26 PM
saikouEF8's Avatar
my car did this when i had a bad ground.
i replaced the dizzy twice like you before i figured it out.
the bad ground was causing the fuel pump to cut out intermittently.
another possiblity....
if the main relay is bad on a Civic, you will lose power to the injectors and the fuel pump but you may not lose fuel pressure because the injectors can't open without power. did u check the main relay with a multimeter?
Old Sep 7, 2006 | 03:45 PM
davin's Avatar
Default Re: no start, but cranks (saikouEF8)
so i just replaced the ECU just now and still the same thing.
how do i check the main relay with the multimeter?
Old Sep 7, 2006 | 08:04 PM
davin's Avatar
and all the grounds are good too :-/
Bryantcuhz
Jul 27, 2014 05:04 PM
adhd316
Honda CR-V & Element
Feb 6, 2014 03:21 AM
davidfischer
Apr 16, 2007 05:11 PM
4crx4me
Mar 27, 2005 03:36 AM
lsvtec hatch05
Jun 23, 2004 07:15 AM
