Im going to choke myself with this O-ring!!!
Old Aug 24, 2006 | 03:27 PM
H22Luda720's Avatar
Default Im going to choke myself with this O-ring!!!
I dont know what the problem is but i cant get this thing to work, i know its the right o-ring bought and part# verified from honda. if anyone is firmiliar with the h22 oil cooler, im trying to get the O-ring between the oil cooler and the block to work, the o-ring is to big for one groove in the cooler and too small for the other, it wants to sit right on that little sharp bump, if it sits there how do you keep it there while you put it on?, i even cosidered if the cooler was on backwards, does the smooth side go in?? i figured the smooth side was for the filter. Please help, this is driving me nuts, thanks
Old Aug 24, 2006 | 03:32 PM
mgags7's Avatar
lol, yea choke yourself dude...haha that gave me a laugh
firstly, the smooth side mates to the block
my best advice is to just sit it in the groove (oil it first), and then try to push it onto the block as quick as you can, just dont let it fall out
common problem though, its a bitch for some, to others its simple, personally, i didnt have any problems with it, but who knows.....
Old Aug 24, 2006 | 03:36 PM
H22Luda720's Avatar
Default Re: (mgags7)
so the smooth side goes toward the block? so that means the the side with the grooves goes out and the oil filter gasket rides on the little bump that the o-ring wanted to ride on?
Old Aug 24, 2006 | 03:45 PM
mgags7's Avatar
just make it so that the coolant pipes face that way....
Old Aug 24, 2006 | 06:50 PM
H22Luda720's Avatar
ok i got it, thanks!
Old Aug 25, 2006 | 03:43 AM
junbb1's Avatar
Default Re: (H22Luda720)
wheel bearing grease holds o-rings in place all day long.
mike1114
Mar 29, 2014 11:00 AM
crossn2theblue1
13
May 24, 2013 09:58 AM
slammedbbs
Dec 2, 2010 08:04 PM
em1 Ziggy
May 12, 2006 11:08 PM
dmxsoulja3
Jan 27, 2005 10:10 AM
