H22 swap passenger tranny mount ??
Im doing an H22 swap in my eg and its automatic so the passenger tranny bracket sits higher than the manual one, whats the best way to adjust the tranny mount so it can fit on the bracket because the bracket sits higher, i already drilled a bigger hole from the pilot hole..any help would be great..
I haven't personally swapped an auto H22 into a Civic, but the best option for you to is to get an HCP type kit that uses the factory mounting location, instead of the HASport type kit which bolts underneath the frame rail..
You're going to need to take measurements accordingly and just work/drill/position it in order to clear the mount..
Pictures would also help
I had the same problem buddy. Just a couple months ago, I had some guy make me a custom passenger tranny bracket who knew what he was doing, and it's been working fine for months now. What u can also do, is order the manual tranny bracket from acura, it was like 80 bucks if I remember, which is alot for a piece of metal, and then take out the spot welds and sand down the frame then weld the new one on. I got a picture of what mine looks like if u want.
huge230
Jul 26, 2005 06:53 AM
patastinky
Jan 20, 2005 06:07 PM
