JDM Transmission Ratios
Doing a search for transmission ratios I have come accross 2 different listings for the JDM Transmissions. I have listed the links below. Does anyone know which are correct.
#1) https://honda-tech.com/zerothread?id=549372
#2) https://honda-tech.com/zerothread?id=1520223
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">there is more than one JDM H22 transmission.</TD></TR></TABLE>
Yes I know. If ou look at the links I posted you will see there are different ratios for the same coded transmission.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">read the faq friend, its all in there.....</TD></TR></TABLE>
I did my friend and other threads, That is exactly why I have the question. In fact the FAQ ia where I started and where the questions begun.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my9thtry »</TD></TR><TR><TD CLASS="quote">im guessing you talking about the M2B4?? because there is a difference in ratios for it. Give us a clue which jdm transmission your reffering to so we know what your talking about. </TD></TR></TABLE>
I am referring to the all the JDMs. In one thread it says the first 3 gears are the same as the USDM VTEC. In another thred it does not say that but it sys there is .2 in third gears from the M2A4 and MrB4.
Am I to belive the third gear in this one example is that much different simply because of the LSD?
In the first example, why would anyone by a JDM if the first 3 gears are the same? These are threads on this site we refer to for reference. I cannot beleive no one picked this up. I am just looking for some consistency before I make a purchase.
