Uh oh...Idle problem....another problem with my H
Old Aug 24, 2006 | 12:15 PM
EvstarH22's Avatar
Default Uh oh...Idle problem....another problem with my H
Ok, I am about to go absolutly nuts. I am having an idle problem with my civic. I have an h22 in a 99-00. I just put on pullies, cam gears, and a flywheel. The car fluxuates its idle from around 500 or 600 rpms to 1000 to 1200 rpms and it just pulses as if i was pressing the gas on and off. Ive checked my vacuum and cant find a leak. Anyone that has any ideas would be greatly appreciated for I am close to dropping a 10 ton weight on my head as I would never do it to my car.
thanks
Old Aug 24, 2006 | 12:19 PM
daoshao's Avatar
Default Re: Uh oh...Idle problem....another problem with my H (EvstarH22)
check to see if you have low coolant levels or bleed your coolant.
Old Aug 24, 2006 | 12:29 PM
bluedlude's Avatar
r you implying putting the pullies and cam gears and flywheel on somehow caused the problem?
Old Aug 24, 2006 | 12:51 PM
2point2's Avatar
how did this start? is it a new swap? more background info.
Old Aug 24, 2006 | 04:24 PM
ViZ's Avatar
ViZ
how did you check for vacuum leaks? did you check the Idle Air Control Valve and the Fast Idle Thermo Valve?
Old Aug 24, 2006 | 06:33 PM
99LudeDude's Avatar
maybe vacuum hoses hooked up in wrong locations. I'm just guessing.
Old Aug 24, 2006 | 09:41 PM
Silkk Tha Shocker!'s Avatar
Had the same problem on mine. 90% sure it's the fast idle valve. Unscrew the 3 bolts holding the valve underneath the throttle body. It'll have a coolant line coming off the front of it. The valve has a plunger-like mechanism inside that opens and closes when the motor is warming up. Check and see if the plunger has worked its way from the pin inside the valve. Simply unscrew the back plate on the valve to access the plunger. Using a flat-head screwdriver, screw the plunger back down some and reassemble the valve. Hope it helps!
Thatssojdm
Aug 5, 2008 07:59 PM
EvstarH22
Aug 24, 2006 06:31 PM
BOOSTED_JDM_DB8
Feb 3, 2006 01:01 AM
stump7117
Mar 27, 2005 09:06 PM
4gen
Jan 11, 2004 05:28 PM
