ODB-II v2 and OBD-II v1 ECU Pinouts
Old Apr 26, 2002 | 01:59 PM
norice's Avatar
Default ODB-II v2 and OBD-II v1 ECU Pinouts
I am picking up a home-made OBD-II v1 to v2 harness and would like to double check the wiring before in install it. (I am going to be using it to install a Comptech ECU for a 1997/1998 Type-R in a 2000 Type-R.)
Does anybody know where I could find the pinouts for v1 and v2 OBD-II ECUs? I have the 1997 Helms supplement, which should have the v1 pinouts, but am wondering where I could find the v2 pinouts.
Old Apr 30, 2002 | 06:06 PM
boomslang's Avatar
Default Re: ODB-II v2 and OBD-II v1 ECU Pinouts (norice)
Email me and I'll send them to you.
Old Apr 30, 2002 | 06:23 PM
ThePunk's Avatar
The 2K helms supplement?
Old Apr 30, 2002 | 06:48 PM
vpc's Avatar
vpc
New User
Default Re: ODB-II v2 and OBD-II v1 ECU Pinouts (ThePunk)
I agree..the best way is to just get the 96-98 helms and a copy of the 99-01 helms to double check. Any other list you get doesn't necessarily mean its correct but it also doesn't mean you can't use it as reference. BTW..I think this might help a bit as well..
https://honda-tech.com/zerothread?id=169121
That one wire (mentioned on Brian99si's reply) is the single difference between Si's and ITR's
[Modified by vpc, 3:51 AM 5/1/2002]
dazebreak
Feb 20, 2013 12:15 PM
punhatch
18
Jan 7, 2004 10:56 AM
mattsy93vtec
Dec 18, 2002 11:13 AM
LiLxrAYCeR
Nov 7, 2002 05:21 AM
Stew Pidasso
Aug 2, 2002 06:25 PM
