Adjusting Driver side Door
Would it be easier to just unbolt the whole door off and line it up again, or are there any specific bolts that I could just loosen up to adjust the height of my driver side door. I noticed that the trim don't line up right, and door is loose. thanks
Get a friend to help you out. Just mess with the four bolts that the yellow lines lead to. If you want to remove the door as well than you have to remove the pin that the green arrow is pointing at but there is no reason to remove the door just to adjust it.
Ali
ketchup
Jun 15, 2009 05:13 PM
