what the??????????can't tell what's going on?
so i'm driving right, all of a sudden my CEL comes on. so when i get to where i'm going and i'm done there i decide to go home, well now the CEL is off. a couple of minutes later it's on. then starts flashing, but not like when your reading a code. more like intermitting. then completely shuts off (keep in mind the car is still running good). maybe about 15 min. before getting home, the car starts to sputter and stall at stops.
so i'm thinking it's my o2 sensor, what do you guys think? need some help here. any advice is better than no advice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC »</TD></TR><TR><TD CLASS="quote">i had a bad o2 and my car never sputtered... if the cel is flashing that means u should prob pull over and shut down.. flashing cel is really bad</TD></TR></TABLE>
once i had the car moving and the rpms were past 3K it rode fine. anything under it would shake as i accelerated, when i would stop, the rpms would jump between 0-1K on idle. if i didn't give it alittle gas it would shut off.
i baby this thing, i hit vtec maybe once, twice a week, if that. no racing, i do my motor oil and tranny fluid changes every 3K miles like clock work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
i baby this thing, i hit vtec maybe once, twice a week, if that. no racing, i do my motor oil and tranny fluid changes every 3K miles like clock work.</TD></TR></TABLE>
wow trans fluid every 3k?!?!? thats def overboard... did u check the cel, see what code its throwing???
I would say its ignition related.. maybe dizzy
Does it feel like its missfiring?
Usually a flashing CEL is the engine saying "I HAVE NO OIL IDIOT" but it seems that this was more of an intermitent CEL like there is a loose connection.
Anyway, check the CEL, if it is there, and check all your fluids, battery, connections grounds etc.
Cars only just up an die for several reasons.
a: a part has failed like your Discharge box or something like that
b: Your out of gas
c: your out of oil and you seized your engine
d: something has become disconnected like a ground or a power wire or some sort of mission critical sensor.
Does it run now?
Do you have fuel? Do you have spark?
I hate these post where someone says:
"It sputtered and died after I got a CEL" that could be ANYTHING. Your post count is high enough, you should know the basics. Help us, help you...
b: Your out of gas
Does it run now?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lonefuzzy79 »</TD></TR><TR><TD CLASS="quote">
"It sputtered and died after I got a CEL" that could be ANYTHING. Your post count is high enough, you should know the basics. Help us, help you...</TD></TR></TABLE>
i have oil, or my oil light will have came on. i have 3/4 of fuel, filled up yesterday morning about 5am. i posted it runs fine after 4K, couldn't even tell something is wrong. the CEL is no longer there, it shut off maybe 5 min after start up. car stalled twice was able to fire it right up, no delays. car starts up no with no delays.
Does it feel like its missfiring?</TD></TR></TABLE>
no i don't think it's overboard, like i said i baby this thing. unfortunately, the CEL is no longer around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soMedic »</TD></TR><TR><TD CLASS="quote">i had a problem like this and it was a throdle positioning sensor. One of the wires had gone bad.... dunno if it's the same for u.
well, i'll take a look at everything, i'm going to replace the o2 sensor anyway. it's only $60 and it's long overdue. i'm just hoping that's it. i have a feeling it is, but my feeling have lead me down the wrong path before. if anyone has any ideas let me know.
thanks!
thanks!
Boosted97Ej8
12
Oct 8, 2012 12:04 PM
dc5bobby
Apr 17, 2010 09:28 AM
terminaloverlowd
Oct 1, 2004 09:03 AM
