Engine Sputters and idles low during rain.
Old Aug 24, 2006 | 08:53 AM
Lude@Heart's Avatar
Default Engine Sputters and idles low during rain.
Ok heres the story.
Everytime it rains, or i run through a puddle of water, Since i have no splash guards, water ends up all over the engine bay. So what part of the ingnition system could water be getting on, causing it to sputter and idle close to dying out. As soon as it stops raining, and i drive for 1 minute its fine again. Now its a brand new cap and rotor. so i doubt water is getting in the distributor.
But i do have a external coil.
Possibly my ghetto internal to external coil wiring? Or old sparkplug wires? Their Autolites, about 5 months old
Its a H22a1 in a 92 civic hatch.
what usually would cause that when it rains. and water gets in the bay.
Modified by Lude@Heart at 6:04 PM 8/24/2006
Old Aug 24, 2006 | 04:57 PM
notstock93's Avatar
Default Re: Engine Sputters and idles low during rain. (Lude@Heart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude@Heart &raquo;</TD></TR><TR><TD CLASS="quote">Ok heres the story.
Modified by Lude@Heart at 6:04 PM 8/24/2006</TD></TR></TABLE>
You arent turbo, you dont need an ignition upgrade. Go back to stock.
Old Aug 24, 2006 | 06:58 PM
Lude@Heart's Avatar
it is the stock ignition system, but civic is internal coil, and h22 is external, so i had to wire the external coil myself.
Old Aug 24, 2006 | 07:17 PM
NathanielH's Avatar
Default Re: (Lude@Heart)
take a mister (like for hair spray or somthing), and spray it all around your plug wires, cap, ect... and check to see if you can see it arching anywhere
Old Aug 24, 2006 | 08:45 PM
notstock93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude@Heart &raquo;</TD></TR><TR><TD CLASS="quote">it is the stock ignition system, but civic is internal coil, and h22 is external, so i had to wire the external coil myself.</TD></TR></TABLE>
My mistake. Check the inside of the dizzy for obvious signs of water, re-qire your coil, check for bare wires anywhere in the bay.
Old Aug 24, 2006 | 08:46 PM
1slowhatchie's Avatar
Default Re: (NathanielH)
do you have a cai if so it might be sucking up water to the motor.
Old Aug 25, 2006 | 03:07 AM
Lude@Heart's Avatar
nope, no CAI its not sucking water its definately ingnition being affected by the water.
I put a new dizzy on from a friend of mine. going to try that for a little.
If it still does it, im going to try my friends internal coil JDM dizzy.
To see if its the external coil gettn wet.
Old Aug 25, 2006 | 07:24 PM
Chiovnidca's Avatar
Try pouring some water over the distributor cap while it's running. Does the engine stall or start running rough?
polishprinze
Oct 30, 2005 02:25 PM
dcb284
Jun 24, 2005 07:43 AM
ridiculus
May 23, 2005 09:27 AM
Outsane
Sep 23, 2004 02:13 PM
Chris Sawatsky
38
Jun 21, 2004 10:06 AM
