can a regualar street tire car hit a 2.0 or better 60'?
Old Aug 24, 2006 | 08:02 AM
wfocrx's Avatar
Default can a regualar street tire car hit a 2.0 or better 60'?
I was just wondering if anyone has ever hit like a 1.9-2.0 60' time with a regular (non drag radial) street tire? Is it possible with?
solid motor mount inserts
full race traction bars
all new ES bushings
complete omni power drag coilover
in a 2050lb crx with about 225whp
Old Aug 24, 2006 | 08:19 AM
94whtgsr's Avatar
I have the older azenis on my integra... I had stock motor mounts with busted tq. mounts and my open differential... my suspension is the apexi exv setup and i had them on half stiff and i have gotten a handful of 2.0 60's before...
Old Aug 24, 2006 | 09:22 AM
raene's Avatar
Default Re: can a regualar street tire car hit a 2.0 or better 60'? (wfocrx)
I hit that on some Nexen all-seasons in my CRX. Barely. 2.08 I think was my best.
Old Aug 24, 2006 | 09:36 AM
Paul_VR6's Avatar
Default Re: can a regualar street tire car hit a 2.0 or better 60'? (raene)
I've cut 1.94's before on a 205/50 street with a 3.94 final and 195whp and 185wtq. It's all about slipping the ever loving **** out of the clutch in 1st and the beginning of 2nd to control wheel spin.
Old Aug 24, 2006 | 10:13 AM
RaceProfessor's Avatar
Default Re: can a regualar street tire car hit a 2.0 or better 60'? (Paul_VR6)
I've pulled a best of 2.09 on kumhos with my old MX-6 beater. Torquey cars tend to be easier because it doesn't become a bog or boil situation.
Old Aug 24, 2006 | 11:51 AM
AllMoToRB18c's Avatar
Default Re: can a regualar street tire car hit a 2.0 or better 60'? (RaceProfessor)
ive hit 2.0 60fts. b4 on 14inch steelies with firestone tires
Old Aug 24, 2006 | 11:56 AM
Paul_VR6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceProfessor &raquo;</TD></TR><TR><TD CLASS="quote"> Torquey cars tend to be easier because it doesn't become a bog or boil situation.</TD></TR></TABLE>
It's just practice either way, honestly I had a harder time cutting 1.9 60s in my six then my 100whp/90wtq Rabbit. Cut consistent 1.95-1.99s in that on streets 195/60s I think. Sliiiiiiip that clutch.
Old Aug 24, 2006 | 12:12 PM
I agree slipping the clutch is key.
Old Aug 25, 2006 | 06:19 AM
BIGTUNA's Avatar
2.02's all day long on 14inch CRX wheels with Futura Super Sports. Had the tire pressure at 13 psi, 2nd gear burnout and preloading the shiznit out of the clutch.
Old Aug 26, 2006 | 01:11 AM
Timmay's Avatar
ive done 1.9's on some bald *** 195/60/14's before.. in a turbo integra
Old Aug 26, 2006 | 10:20 AM
Skilz10179's Avatar
Default Re: can a regualar street tire car hit a 2.0 or better 60'? (Timmay)
I've cut a couple 2.0 60' times using KDW2 street tires. My car weights about 2800, if it was as light as most of the cars on this site i'm sure it could have been better.
Old Aug 27, 2006 | 12:23 PM
njn63's Avatar
My friend with a stock MKIII VR6 cut a 2.08 once. I'm not sure what tires he had on it but i don't think they were that good even and it is a low 15 second car. Shocked me.
Old Sep 4, 2006 | 02:00 PM
wfocrx's Avatar
would 225/50-16 tires be a good size street tire to use
oh...
I can't really slip the clutch too much since it is a 6-puck race clutch
Old Sep 4, 2006 | 04:43 PM
boosted94cx's Avatar
* B A N N E D *
1.9 60 on 185/65/14 aqua tread 3's @ 20psi
car was an RLZ built 2.1L making 2-teens at the wheels. no preload, no clutch slip...jsut a small burnout and dumped it at 3500
Old Sep 7, 2007 | 08:47 PM
daver's Avatar
how do you slip the clutch in second gear? do you powershift with the clutch partially depressed? its easy to slip in first, because your already set at the tree.
just put in a new itr tranny and clutch and now my 60' times are killing me with spinning through 2nd and part 3rd. i was thinking of backiing off the gas for a sec, right after the shifts to settle the clutch grab..
d
Old Sep 8, 2007 | 05:25 AM
Paul_VR6's Avatar
Default Re: can a regualar street tire car hit a 2.0 or better 60'? (daver)
After I put it in 2nd I just bring the clutch out slowly. It sounds retarded but anything to combat spin helps.
Old Sep 8, 2007 | 07:06 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
1.9's on $42 federalies!
Old Sep 8, 2007 | 05:10 PM
daver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul_VR6 &raquo;</TD></TR><TR><TD CLASS="quote">After I put it in 2nd I just bring the clutch out slowly. It sounds retarded but anything to combat spin helps.</TD></TR></TABLE>
i find it so hard to find the time to do anything other than kick the clutch pedal..shift..full throttle. all in one motion.
i tried binging the clutch pedal out only halfway after the first shift for some more slipping, seems like it takes extra time fooling around with that stuff. i was doing ok for traction today tho anyway, good hot pavement-&gt; that seems to be the ticket. I broke into the 2.1x 60' once today, with very little spin into second 28psi.
guy in a crx with the identical engine setup as mine was trapping 102mph to my best 97.9mph. weight makes a big diff. he has bfg's drag radials and didn't know how to use them, and still hit a 13.6 to my best 14.2
PINKS
Mar 13, 2007 04:39 AM
DPSJosh
Aug 24, 2006 06:23 AM
RacerStev
Jun 8, 2006 12:16 PM
ptownsintegra
Aug 25, 2005 08:21 AM
Evil DOHC
Nov 2, 2002 10:36 PM
