1st swap.. im very confused!! (searching while asking) please help
Old Aug 24, 2006 | 04:46 AM
hondahatch741's Avatar
Default 1st swap.. im very confused!! (searching while asking) please help
Modified by hondahatch741 at 4:15 PM 8/28/2006
Old Aug 25, 2006 | 01:38 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: 1st swap.. im very confused!! (searching while asking) please help (hondahatch741)
Check out my site for a link to the distributor colors to depin and swap over and the sensor wiring is very simple. The Vacuum wiring is very simple, one line should go from the intake manifold to the fuel pressure regulator on the fuel rail, one from the intake manifold to the PCV valve, one from the throttle body to the charcoal canister (red thick tube), one from the throttle body to the charcoal canister (thinner black tube) and one goes to the brake booster from the back of the intake manifold. If you have any additional tube or ports coming off the Y8's manifold just tap them in to another line or put a tube on it and block off the tube with a bolt or something.
mitchh29
15
Mar 13, 2013 11:53 AM
driftam1
Apr 26, 2008 04:17 PM
PINKS
Mar 23, 2006 02:38 AM
95DxSi-R2
Mar 17, 2006 09:22 AM
