Need help with DB8 doors (searched)
Old Aug 24, 2006 | 01:39 AM
kauaiboy66's Avatar
Default Need help with DB8 doors (searched)
I'm posting for my friend and he's going to order the db8 doors he was wondering if it will just bolt on and plug in with the stock harness or you have to do some wiring...
thanks for your help in advance...
Old Aug 24, 2006 | 09:54 AM
XxNampsterxX's Avatar
Default Re: Need help with DB8 doors (kauaiboy66)
I just did this. If you're talking about the JDM ones, then your friend is going to have to switch the wiring from the two front doors, window rail and motor, and the power door lock actuators. In Japan, the driver door is on the right. I had to use all the stuff from USDM doors. The backs are pretty much plug ang play. The only problem I ran across is that my power door locks don't work anymore, but I'm trying to figure it out now. It's pretty easy to do.
Old Aug 24, 2006 | 12:55 PM
kauaiboy66's Avatar
Default Re: Need help with DB8 doors (XxNampsterxX)
yea that's the one with out the moldings can you get me some pics when it's all done..
thanks<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kauaiboy66 &raquo;</TD></TR><TR><TD CLASS="quote">I'm posting for my friend and he's going to order the db8 doors he was wondering if it will just bolt on and plug in with the stock harness or you have to do some wiring...
thanks for your help in advance...</TD></TR></TABLE>
Old Aug 24, 2006 | 01:52 PM
I'm already done with the door swap. What pics did you want? The wiring? The door?
Old Aug 24, 2006 | 02:15 PM
EnjoyTheRideDC2's Avatar
Just swap over the wiring harnesses from the USDM doors onto the JDM doors. For the Power folding mirrors, just seperate the plugs needed and run it with the USDM harness. Make sure you also swap over the door control relay on the USDM Drivers door to the JDM one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XxNampsterxX &raquo;</TD></TR><TR><TD CLASS="quote">I just did this. If you're talking about the JDM ones, then your friend is going to have to switch the wiring from the two front doors, window rail and motor, and the power door lock actuators. In Japan, the driver door is on the right. I had to use all the stuff from USDM doors. The backs are pretty much plug ang play. The only problem I ran across is that my power door locks don't work anymore, but I'm trying to figure it out now. It's pretty easy to do.</TD></TR></TABLE>
Why'd you have to switch over the window assemblies from the doors? And the actuators?
And the power door locks...Use the USDM Relay box. Its the brown box screwed onto the drivers side door, towards the rear view mirror.
Old Aug 24, 2006 | 03:32 PM
Default Re: Need help with DB8 doors (EnjoyTheRideDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
I switch out the window assembly because the motor is connected to it and the harness to the motor is different between the driver side and the passenger side. Same thing with the actuator.
ludatic98
Jan 29, 2009 07:06 AM
usdm-ferio
Sep 4, 2006 01:03 PM
dcdcdc
May 2, 2005 11:09 PM
ricearoni56
10
Apr 21, 2004 06:44 AM
Civiclx
Jun 20, 2003 11:29 PM
