B16 swap - how to remove hubs?
Old Apr 26, 2002 | 12:58 PM
doggunracing's Avatar
Default B16 swap - how to remove hubs?
Title says it all, we've gotten the brake stuff off and the big nut, but how does the hub come off of the axle? This is on a '91 CRX.
Thanks,
Keith
Old Apr 26, 2002 | 01:19 PM
markedOO1's Avatar
Default Re: B16 swap - how to remove hubs? (doggunracing)
hub off the axle or hub off the car? if you mean hub off the axle...just pull it off. if you mean hub off the car, take off the upper and lower ball joints and anything else you see holding it on (cant think right now)
Old Apr 27, 2002 | 07:50 AM
Default Re: B16 swap - how to remove hubs? (marked001)
Well, we need to put in the different axles, so I think we only have to take the axle out of the hub. So after taking off the nut, the axle should just pull out the back of the hub?
Old Apr 27, 2002 | 08:01 AM
91sifreak's Avatar
New User
Have you already taken the end that is in the tranny out, or the castle nut on the bottom of the hub and separated the LCA from the hubby assembly, If not take of the castle nut on the bottom, then separate the ball joint. That will allow the hub to swing out and of the end of the axle. then use a large screwdriver or a tire iron to seperate the axle from the tranny, and out comes the axle. Make sure to drain tranny first too. How that helps
thw_goalie
Aug 12, 2012 10:39 AM
minvi
Jul 28, 2010 11:44 AM
Mr. Giggles
Jan 23, 2007 06:15 PM
RicedREX
Feb 26, 2004 05:33 PM
kshymkiw
Dec 5, 2002 06:56 AM
