ITR owners with Hondata Gasket
I will be pulling my intake manifold on my ITR this weekend, just wanted to know from ITR owners that have installed the Hondata intake manifold gasket if they had to run longer studs. I was told some cars do and others don't, no ryme or reason.
Thanks Mattj
Thanks Mattj
I haven't installed mine yet...but G3-TEG is already running his with the ITR in-mani and ITR cyl. head....
no problems....slide it on....bolt everything back up and away you go....
No problem with the stock studs...works great too. Didn't have time to bypass the cooling system, but the manifold temps are way cooler than before.
Austin
Austin
Yup.. no problems.. and world of different in intake temps.
Pics and instructions here:
http://www.c-speedracing.com/howto/h...atagasket.html
Thanks again. I'm having the Intake manifold flange "angle cut" also to straighten the air flow from the intake manifold into the head.
Mattj
Mattj
Mattj
Mattj
Please explain furthur.
I'll make it qwik. The smoother the path the air must flow the better. Basically the flange for the intake manifold has material removed from the top on an angle-down so the runners for the Manifold are getting closer to the same angle as the ports into the head. If you were to look at the engine from the side the TB and back of intake manifold will be sitting slighly higher than they were before. Mattj
Dynospot Racing sells them. They have been on backorder for awhile now, however Dynospot and a few others have gotten them in. http://www.dynospotracing.com
EuRoBrO
Aug 10, 2004 06:34 PM
silverstreak20
12
Mar 21, 2004 02:18 PM
