first time at the track...i think i need an h22 tranny
Old Aug 23, 2006 | 09:10 PM
snzh22's Avatar
Default first time at the track...i think i need an h22 tranny
so yea i hit the track for the first time.
here are my mods...the ones that matter at least
h22 with i/e/dc header, pullies, removed egr and balance shaft belt, phearable chipped p28 still on basemap, and f22 tranny, wanli tires 205/40/17 tires at 23 psi
its not that bad for the first time..considering my tranny and tires
but do you guys think that the gearing of an h22 tranny will help me a lot? i was aiming for mid to high 14s...
i also had tons of wheel hop
Old Aug 23, 2006 | 09:25 PM
98vtec's Avatar
moderator emeritus
Default Re: first time at the track...i think i need an h22 tranny (95hprelude)
with the h22 tranny and nice tires, you got mid-low 14's with practice.
Old Aug 23, 2006 | 09:30 PM
snzh22's Avatar
Default Re: first time at the track...i think i need an h22 tranny (98vtec)
is the 2.3 60' decent even tho i wheel hopes thru some of it?
Old Aug 23, 2006 | 09:31 PM
snzh22's Avatar
also i noticed my driving is pretty consistent...i got 2 runs at 15.1@93 and 1 at 15.3@93
Old Aug 23, 2006 | 09:37 PM
98vtec's Avatar
moderator emeritus
your 60ft could be better. But you can only ask so much of your tires and wheel hop. Some motor mount inserts and a nice suspension will take care of that.
Old Aug 23, 2006 | 09:54 PM
TylerC161's Avatar
I pulled a 14.7 on my prelude..
at the time it was h22a, f22 tranny, CAI, RSR exhaust, stock header
Old Aug 23, 2006 | 09:56 PM
snzh22's Avatar
Default Re: (TylerC161)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TylerC161 &raquo;</TD></TR><TR><TD CLASS="quote">I pulled a 14.7 on my prelude..
at the time it was h22a, f22 tranny, CAI, RSR exhaust, stock header</TD></TR></TABLE>
what was ur trap, tires, and weight?
98: i have neuspeed springs/tokico struts...but no inserts yet.
Old Aug 23, 2006 | 10:05 PM
blackdelslo's Avatar
Your missing out. h22 tranny ftw
Old Aug 23, 2006 | 10:21 PM
petern101's Avatar
Default Re: first time at the track...i think i need an h22 tranny (delLudeVTEC)
jw, why would you install a phearable ecu if its still on a basemap?
its basically like the ppl that install safc's/vafc's and never get them tuned but it sure does look purdy in the lude....
you could probably get into the high 14's easily if you got a good tune.
maybe even getting rid of that dc header and you are good to go.
Old Aug 23, 2006 | 11:50 PM
Rudaluda's Avatar
why not go with an h23 tranny....longer 3rd gear....and a euro-r 5th gear ftmfw!!!
Old Aug 24, 2006 | 12:42 AM
paulwithap's Avatar
when i get back in the country, i'll have to take mine to the track. i have h22 with i/h/e and h23 tranny. the only thing i notice, is that it falls out of vtec from 1st to 2nd. other than that i like it.
Old Aug 24, 2006 | 06:12 AM
snzh22's Avatar
Default Re: (Rudaluda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rudaluda &raquo;</TD></TR><TR><TD CLASS="quote">why not go with an h23 tranny....longer 3rd gear....and a euro-r 5th gear ftmfw!!!</TD></TR></TABLE>
i was also thinking about that...not only because of the price, but also because i think the only gear thats really different is 2nd gear. but then again i really hate falling out of vtec. 1st is same as the others, and i believe that the 3rd is only .02 different from the 5th gen h22 trannies, and 4th and 5th are pretty much the same.
5th gen h22
M2Y4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266
4h gen h23, taken from 92lude.com
M2S4 - 3.31 - 1.86 - 1.32 - 1.03 - 0.81 - 4.27
i think the h23 trannies only go for around 250-350, where the h22 tranny goes for around 6-700
Old Aug 24, 2006 | 08:08 AM
petern101's Avatar
Default Re: (95hprelude)
jdm h22 tranny ftw.
for most preludes, the shorter gears (i think 2-4) and much taller 5th gear for highway cruising
Old Aug 24, 2006 | 09:36 PM
snzh22's Avatar
video...
http://www.youtube.com/watch?v=raK3RFA1voA
not that exact run, but one with very similar results
Old Aug 24, 2006 | 10:15 PM
Twilightepitaph's Avatar
yea, i have heard that the f22 tranny is good if you have a boosted h22 because of the longer gear ratios but not so good if you are running n/a. If you do get a new tranny you might look into a lightweight flywheel and an upgraded clutch if you want to go that far while it is out of the car. and Don't go directly to the track after the swap. You want to get used to the new tranny. I have seen so many "i changed my tranny and my numbers are lower" and "i got a stage "4" clutch and my quarter mile sucks now" threads where people change out their stuff and hit the track thinking they will make some powerfull gains but they haven't driven their car enough to know how and when to shift right.
but yea, definatly get the h22 tranny. And if you can find one with the lsd, that would be a plus. I don't know how they handle at the track but they do wonders in bad weather.
Good luck.
Old Aug 25, 2006 | 04:42 AM
flyrod's Avatar
Default Re: first time at the track...i think i need an h22 tranny (Twilightepitaph)
Heh, good one.... got tricked into looking at this thread. I think you are talking about a drag strip.
Old Aug 25, 2006 | 02:03 PM
mark34256's Avatar
Default Re: first time at the track...i think i need an h22 tranny (flyrod)
you could use some help with your reaction time? .8 is really killin you
Old Aug 25, 2006 | 04:45 PM
jakeiscool's Avatar
Banned
your trap speed is good for 14.9 probably.
Old Aug 30, 2006 | 01:19 PM
snzh22's Avatar
Default Re: first time at the track...i think i need an h22 tranny (JakeIsCool)
i should be gettin an h22 tranny soon and hopefully 98vtec is right!
Old Aug 30, 2006 | 06:09 PM
M2B4's Avatar
M2B4 FTW JDM LSD BABY
rico892002
Aug 18, 2009 04:01 PM
H22_aCCoRd_07
Aug 31, 2007 07:09 PM
BergRacing21
Jan 12, 2006 03:43 PM
