Help! car problem...!!!
Old Aug 23, 2006 | 08:21 PM
The Si's Avatar
Default Help! car problem...!!!
Modified by The Si at 8:43 AM 10/17/2007
Old Aug 23, 2006 | 08:23 PM
Jhonny Ricer's Avatar
Default Re: Help! car problem...!!! (ThaSi)
...... if it werre the battery orrrr the alternator your car wouldnt be working at all....
duh??....
sounds like a bad fuse check your fog lights fuse in your fuse box and replace it if it needs to and try getting the ac recharged and check its relays could also be a bad compressor
take it to a mechanic...
Old Aug 23, 2006 | 08:25 PM
turbociviccoupe's Avatar
Default Re: Help! car problem...!!! (Jhonny Ricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jhonny Ricer &raquo;</TD></TR><TR><TD CLASS="quote">...... if it werre the battery orrrr the alternator your car wouldnt be working at all....
duh??....
take it to a mechanic...</TD></TR></TABLE>
Old Aug 23, 2006 | 08:36 PM
The Si's Avatar
Default Re: Help! car problem...!!! (turbociviccoupe)
cool anythin else..
Old Aug 23, 2006 | 08:38 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> x2
There's 1001 reasons why ur AC won't work..so you might not want to immediately chalk it up to the same problem as your fog lights.
As far as they go, check the fuses, the relay, and the ground. After that override the switch and see if you could "jump" the light. From there move onto the wiring and trace every step of it. I doubt the two problems are related actually, though it is possible I suppose. It's not ur battery or your alt. because your car wouldn't be putting out a spark (aka. it wouldn't be running). See if you can look for the problem with your fogs in what I just said. Then move onto your AC, like I said, I don't think they're connected (the problems).
Old Aug 23, 2006 | 08:48 PM
The Si's Avatar
Default Re: Help! car problem...!!! (Syndacate)
thxx
JJT211
32
Aug 5, 2013 05:49 PM
Diet coke boii
19
Jun 10, 2007 12:54 PM
cruzersi99
Nov 24, 2003 06:47 AM
bocian
Jun 7, 2002 07:25 AM
Woody_geeser
Aug 23, 2001 05:42 PM
