Fuel Regarding Topic-Compression
i just remembered that the mechanic said fuel is not coming into the valves . so how much is a fuel pump be for a 94 LS be? and could that really be the problem?
those things getting fixed shouldnt cost as much as a new fuel pump or anything ?
and having those problems can make your car not start?
If it is the fuel pump (which I seriously doubt), a Walbro 190lph pump can be purchased on ebay for less than $100 and installed by any retarded monkey with hand tools.
Again, I seriously doubt fuel is the problem. First, check the ignition components, then run a compression test, then go on to troubleshooting the fuel system.
Cameron60
Jan 16, 2007 06:04 PM
