Removing wires from ecu
Old Apr 26, 2002 | 12:21 PM
CivicEx95's Avatar
Default Removing wires from ecu
Hey there, I'm in the process of my swap, and I'm having a hard time pulling out individual wires from the plugs into the ECU. How do these things come out? Thanks.
Old Apr 26, 2002 | 12:27 PM
Missingsohc's Avatar
Default Re: Removing wires from ecu (CivicEx95)
first pull the white retaniers then stick a smalll screw driver like eyeglasses size into the hole of the pin you want push the wire down in to the plug and push the screw driver in it sould pull right out......
Old Apr 26, 2002 | 12:39 PM
CivicEx95's Avatar
Default Re: Removing wires from ecu (JDMET-2)
ok, im not understanding that. look at these pics
Thats the one i need to take out, but how do you get them out? How are they stuck in there?
Old Apr 26, 2002 | 05:24 PM
first pull the grey thing off next to the wires on top of the plug. then stick a small screwdriver in the the hole directly above the pin on the bottom of the plug. next push the pin and wire down from the top of the plug and push the screwdriver in and down and pull on the wire it should slid right out
if this is to hard to understand try hasports website.......
danteisme
Audio / Security / Video
Sep 29, 2016 04:33 AM
RCautoworks
Jan 25, 2006 05:16 PM
Ronin150
Apr 10, 2005 05:35 PM
TeamDOHCside
Dec 25, 2003 09:46 PM
