p72-2 stamped on my block, what does it mean?
Old Aug 23, 2006 | 06:03 PM
tegswin's Avatar
Default p72-2 stamped on my head what does the -2 mean?
Hey guys I need some help. I've searched ti and ht with next to no results (at least no definitive answer)
I just bought a new starter (mine died) i puleld it , took to vatozone and got another.
Heres where it gets tricky...
I swear for the life of my the bolt will not line up in the top of the starter if the starter is flush with the block.
i have a gsr motor in an LS (what year i dont know) It seems that the starters might have changed a little in newer years. My car is a 95, naturally I bought a 95 starter for a gsr...
my block says p72-2 ... does that mean OBD II ? if so wouldn't that mean it is newer than 95 / 96 and most likely mean I have the WRONG starter?
please help -- what does p72-2 on the block mean? gsr ... what?
Modified by tegswin at 5:51 PM 8/24/2006
Old Aug 23, 2006 | 06:06 PM
mike9571's Avatar
Default Re: p72-2 stamped on my block, what does it mean? (tegswin)
Are you sure your getting a starter for a manual?
Old Aug 23, 2006 | 06:08 PM
tegswin's Avatar
Default Re: p72-2 stamped on my block, what does it mean? (mike9571)
yep i even checked the part number from autozones website with the part I have :/
Old Aug 24, 2006 | 07:26 AM
smutmonger's Avatar
either one should fit just fine.
if nothing else just go back and exchange it for an LS one.
but as long as they are both for a manual it should fit.
Old Aug 24, 2006 | 07:38 AM
skunked's Avatar
Default Re: (smutmonger)
any 5spd manual B series starter will work
Old Aug 24, 2006 | 10:04 AM
gsr dood's Avatar
Default Re: (skunked)
sure they didnt give u an automatic starter?
gsr dood's Avatar
Default Re: (gsr dood)
or u mite have to move the flywheel a little bit to sink the teeth into it so it sits flush.
Old Aug 24, 2006 | 01:10 PM
Usagi Yojimbo's Avatar
From: Dont say my car is topless say the titties is out
I just had a question. Did you misspell Autozone in the first post or did you mean to call it vatozone.
Old Aug 24, 2006 | 02:01 PM
Tornadom's Avatar
Take the car out of gear... trust me.
Old Aug 24, 2006 | 02:47 PM
mike9571's Avatar
Default Re: p72-2 stamped on my block, what does it mean? (Tornadom)
Isnt the p72 on the head?
anyways All b-series manual starters are the same. It sounds like you have an auto starter, hence the bolts wont line up.
Old Aug 24, 2006 | 04:46 PM
tegswin's Avatar
haha
vatozone on purpose (we call it that in az) lotsa mexicans in az and i guess its kinda racist to say - sorry haha.
but yes i think you're right p72 is stamped on the head mine says p72-2
meaning gsr (but obdII im guessing)
Heres the update
*******UPDATE*******
went back to Autozone, asked to see my old starter, i swore it would not go in so he pulls it out and crossreferences the honda part number, turns out 96+ gsr starter is diff than 95 or lower.
So i ordered a 96+ starter that matched my old part
aka
My motor is not a 95, but a 96-01 gsr swap
Thanks for your help, although nobody has definitively said what p72-2 means
IF YOU KNOW PLEASE REPLY!
if its obdII vs. like p72-1 might mean obd1? i dont know haha.
Thanks guys
Old Aug 24, 2006 | 04:58 PM
RHDintegXsi's Avatar
you beat me to it..but i HEARD obd1 and obd2 b series starters are different and not interchangable
civicmc97
Aug 27, 2010 10:51 AM
Swiss Gary
Mar 17, 2007 05:54 AM
SiMateoAko
Aug 17, 2005 12:12 AM
STUCKED
Mar 23, 2005 11:14 AM
civbeater90
Nov 8, 2002 03:10 PM
