i need some help please.. i did search....
Old Aug 23, 2006 | 05:48 PM
2.2's Avatar
2.2
Default i need some help please.. D15b :(
hi my brother has a 93 civic vx and his engine finally died after 170k miles. he took it to a shop to get a new engine put in. the put instead of a d15z1 a d15b. but only the long block. they used the vx ecu ,intake mani, exhaust mani, tranny.
from what i researched, i called the guy that did the work and told him that these parts needed to be replaced. he said that it didnt....
we bought a p08 ecu and installed an a d16y8 intake mani. soon to be installed.
my question is
1. the engine didnt come with the 1 wire d15b 02 sensor so the 5 wire d15z1 o2 sensor is being used.
is this ok?? or will it cause harm..
2. is there nething else that needs to be replaced.
i have been doing research and i could use ne help.
i am not too familiar with civics. i own an S2000
so any help with this problem is greatly appreciated
thanks in advance
justin
Modified by 2.2 at 7:07 PM 8/25/2006
Old Aug 23, 2006 | 05:49 PM
2.2's Avatar
2.2
oh and it is boging at low rpms but once above 4-5 k it runs smooth.. could this be fuel injectors or the fuel pump????
i dont think they have been replaced ever...
thanks
justin
Old Aug 24, 2006 | 12:40 PM
2.2's Avatar
2.2
TTT
Old Aug 25, 2006 | 12:45 PM
2.2's Avatar
2.2
Bump .... NEONE?????
Old Aug 25, 2006 | 03:11 PM
hatchi's Avatar
Default Re: i need some help please.. i did search.... (2.2)
if he reused your vx ecu then you will need to run the corresponding o2 sensor which is the 5 wire o2 sensor.
all the parts are interchangeable on the longblocks so he reused all the parts off the vx. check the timing on the bogging issue and plug wires/sparkplugs
Old Aug 25, 2006 | 03:16 PM
ph0shizzle's Avatar
Default Re: (2.2)
hey i got a jdm d15b swap in my car too. but im runnin a p28. im just wonderin if the p08 ecu is supposd to be the correct ecu for the 3stagevtec, is ur d15b vtec? if so ur ecu must be jdm also. where did u get it at?
Old Aug 25, 2006 | 05:41 PM
2.2's Avatar
2.2
yeah its the d15b.
he used the vx ecu.
but we replaced it with the P08 ecu...
Old Aug 25, 2006 | 06:06 PM
2.2's Avatar
2.2
from what i read, a d16 y8 intake mani will bolt up to d15b... but is there any modifications needed??????
i read posts that say 2 different things..
i am confused
wolfsbain
Feb 25, 2012 01:20 PM
_RedRiceR_
Jul 6, 2006 11:55 AM
DeezNutts
Mar 3, 2006 08:29 PM
Eg6xCiViCxSi
Feb 27, 2005 09:35 AM
