should i use this 92-95 Liquid filled EG motor mount on my integra?
so i baught a JDM LS motor from HMOtors and it dsnt seem to fit with my USDM LS motor mount.. and i call HMO and they are tellin me the bracket is diff in JAPAN then US, so i need to get a 92-95 EG LIQUID FILLED motor mount ( the driver side mount ). wondering #1 should i switch over and use this EG liquid filled motor mount even though i hear they break alot and i dunno if they can stand and last /w my turbocharged LS motor. or #2 go through the trouble of switching over the bracket off my motor that came out the B20. but that is alot of work consdering i will have to take off the crank pulley etc and motor is already bolted into my car, just need this last motor mount and put in axle..
please help.
this is where the mount goes
this is what the motor mount looks lke for integras but it ddsnt fit with the bracket on my motor
please help.
ever think about hasport? if you need just the driver side, call deven, he call buy seperate from sportcarmotion
id recommend you go through the trouble and switch it out for the integra one. sooner or later you'll regret putting the liquid filled one on.
*dont half *** on the job, especially if you already have the parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious »</TD></TR><TR><TD CLASS="quote">id recommend you go through the trouble and switch it out for the integra one. sooner or later you'll regret putting the liquid filled one on.
*dont half *** on the job, especially if you already have the parts.</TD></TR></TABLE>
i 2nd that
it seems as though your getting burnt out with all the work..i dont blame you. take a day off to chill, then come back another day and do it the right way. no use in spending extra money when you have a perfectly good mount and bracket
i 2nd that
ic, thanks 4 everybodys opnion. this is what i had in mind in doing tonight. was just making sure that i was right that the EG liquid filled ones are crap. and i already talked to devin about it. i dont have $$ for hasport.
J.nguyen
Aug 24, 2006 03:20 PM
tspkenneth
Dec 16, 2004 08:58 AM
