Suspension & Brakes Theory, alignment, spring rates....
Question about my Suspension
Old Aug 23, 2006 | 05:33 PM
CRX MASE's Avatar
Default Question about my Suspension
I have GC coilovers and Tokico Illumina's, i lowered my car to were the front tires are tucking, and i had to lower the rear all the way down to level things out. My drivers side rear is right but the passenger side has a half inch gap between the tire and 1/4 panel, and both side are all the way down. What could be causeing this?
Old Aug 23, 2006 | 06:55 PM
Tyson's Avatar
Default Re: Question about my Suspension (CRX MASE)
cars are weighted unevenly. its not surprising. and after 18 years of use, the bushings are going to be offset, some more than others, futher making the car "unlevel". and lastly, did you tighten all your bolts under load? its important for the life of your bushings.
you should not expect the car to sit even when each perch is relatively at the same location. adjust them individually. thats the point.
after saying all this, however, you are way too low. especially on a crx.
MR_Ek4
Suspension & Brakes
Sep 8, 2006 03:34 PM
jond
Suspension & Brakes
Aug 29, 2006 03:00 PM
ziggen243
Suspension & Brakes
Sep 15, 2005 04:37 PM
deviant1
40
May 1, 2004 08:13 PM
cyberx
10
Mar 28, 2003 12:18 AM
