taillights, dash, shifter lights
ok my running taillights aren't working neither is my dash lights nor the lights on my shift position.. i replaced the fuse for these. but they still aren't working.. any tips on what it might be? when i replaced the fuse it was blown.. but they are still not working
Modified by Tazragoon at 6:24 PM 8/23/2006
mite have a bad ground somewhere...i have the same deal wit my reverse lights..that jus dont work anymore..
take out your cluster follow all black wires that lead to it make sure they are attached to bare metal
check your cluster bulbs could be shot
che ck the harness behind your cluster mfor any splits in the rubber covering and so on if yoiu dont know that much you might just whant to take it to a mech and see if they can find the prob
my freind has a 94 gsr and has tried everything including replacing the cluster among other reasons to see what the problem is and he is still running with a pair of blue neons on his cluster
maybe a bad relay but im not even sure that you have one
Xathine
19
Feb 4, 2009 04:27 PM
