turbo exhaust manifold, will it fit? d series
i found an eclipse or talon with a stock turbo manifold, it was a sohc mitsu engine, and i want to know if that will fit my 96 d16 civic and what psi it holds, cause i've been told some mitsu parts will fit d series civics
you can use the 14b on the d motor and make decent power, i think the stock wastegate is set to around 8 psi? you will need a manifold for a d motor though, hf manifold with an adapter is the cheapest route.
monkeylab9
Jun 27, 2008 03:50 PM
