Integra Driver side motor mount.. are OBD-i and OBd-II SAME THING??!!
Old Aug 23, 2006 | 04:16 PM
J.nguyen's Avatar
Default Integra Driver side motor mount.. are OBD-i and OBd-II SAME THING??!!
swaping in my new LS motor from HMotors and ran into trouble when trying to put in the driver side motor mount. it dsnt seem to fit with the bracket. thing was it was used on the b20 OBD-II Block and it had no problem, but when trying to put it on this B18B it did not fit. now before i start tearing it apart and switching the brackets, i remember My old integra (94 LS) that mount was BLACK and so was my friends 95 LS special edition. so my question is if i go look for and buy a black one OBD-I mount.. will it fit.. or is my Bracket wrong b/c on the head of my HMotors motor it shows 9/0 so i believe its a 91 motor.. but it says b18B on it., so its not a DA b18A motor.. please help. pictures are below.
heres a pic of it. but its an OBD-II model. is it same as OBD-I MODEL??
it goes here:
Old Aug 23, 2006 | 04:27 PM
J.nguyen's Avatar
Default Re: Integra Driver side motor mount.. are OBD-i and OBd-II SAME THING??!! (Jesse.)
ANYONE?!!
Old Aug 23, 2006 | 04:33 PM
lVlemphizStylez's Avatar
as far as i know the mounts dont change from obd1 to obd2
Old Aug 23, 2006 | 04:38 PM
J.nguyen's Avatar
Default Re: Integra Driver side motor mount.. are OBD-i and OBd-II SAME THING??!! (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">as far as i know the mounts dont change from obd1 to obd2</TD></TR></TABLE>
fck... then i gotta switch over my Mounts.. thats gonna be a bithc..
Old Aug 23, 2006 | 04:43 PM
i dont see from your picture why the mount you posted wont work...it looks like the engine needs to be jacked up some and pushed back so you can slide the mount on...thats all...
Old Aug 23, 2006 | 05:05 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">i dont see from your picture why the mount you posted wont work...it looks like the engine needs to be jacked up some and pushed back so you can slide the mount on...thats all...</TD></TR></TABLE>
its on a cherry picker. it wont even fit into the Mount when it was outside of the chasis. the holes are too far apart.. im hearing the bracket on my motor is for like an ek or something..
Old Aug 23, 2006 | 05:12 PM
bluemax189's Avatar
nope i got the same bracket on my 00 ls. maybe they did change it.
Old Aug 23, 2006 | 05:15 PM
J.nguyen's Avatar
Default Re: Integra Driver side motor mount.. are OBD-i and OBd-II SAME THING??!! (bluemax189)
Nvm, i think obd-i and obd-ii are the same thing b/c i just called HMotors and they are tellin me that the JDM ls motor mount is used differently and the only mount that i can get to work are the liquid filled eg mounts 92-95
Anythingbtcivic
Feb 13, 2013 12:37 PM
poorhonda
10
Aug 25, 2009 04:19 PM
J.nguyen
Aug 23, 2006 07:35 PM
J.nguyen
Aug 23, 2006 05:15 PM
Ransom
Sep 10, 2003 11:36 AM
