when do i start using higher grade fuel?
the title of the post pretty much says it but i was just wondering as your modding your car when is a good poit or at what point should i switch to a higher grade fuel or do i ever have to switch to higher grade fuel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style »</TD></TR><TR><TD CLASS="quote">Anytime your setup is prone to detonation such as with higher compression ratios or forced induction.</TD></TR></TABLE>
you can run lower octane fuel but it is harder to tune and you will lose optimun performance
anything from 10:1 to 12.5:1 I would run premium fuel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 »</TD></TR><TR><TD CLASS="quote">So, generally the higher the comp. the higher octane needed?
yes unless your car has a forced induction system such as a turbo, supercharger, or nitrous
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by endorfinch »</TD></TR><TR><TD CLASS="quote">so i should start using 91 once i put on my vtec head and cams or could i still run 87 safely.</TD></TR></TABLE>
91 octane
91 octane
yes it i highy recommend it. esp if your running vtec. 91 is the highest in san diego . but i know in other places you can get higher.
i use plus....any car my family owns has always used a high grade...i think its just better and cleaner, so why not, but gas prices suck! ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra racr04 »</TD></TR><TR><TD CLASS="quote">i use plus....any car my family owns has always used a high grade...i think its just better and cleaner, so why not, but gas prices suck! ...
Use regular for an LS. You will get better mileage and your car will be faster. Premium fuel is not necessary for an LS.
Hondaaaaa
Feb 16, 2008 04:16 AM
