what u guys use to lock cam gears at tdc?
Old Aug 23, 2006 | 12:42 PM
integlstrike1's Avatar
Default what u guys use to lock cam gears at tdc?
what did you guys use lock cam gears at tdc? what size is the holes that line up? lol so far i been using phillip screwdrivers lol, is it 5mm pin punches i use??? and also where can i get em??? any help is good helps tanks
Old Aug 23, 2006 | 12:44 PM
lVlemphizStylez's Avatar
Default Re: what u guys use to lock cam gears at tdc? (integlstrike1)
i use the punches ....as long as what you fit in the hole has NO play to move back and forth...it should lock them TIGHT
slowboy90
Aug 30, 2009 07:14 PM
bluecal
Feb 18, 2004 07:29 PM
fastludeh22
Nov 20, 2002 07:38 PM
