MSD Plus 6 problem
Old Apr 26, 2002 | 11:17 AM
TypeR00_0371's Avatar
Default MSD Plus 6 problem
I installed the MSD Plus 6 with the Blaster SS coil....tapped into my stock distributor ......everything fires, but at full throttle @7500rpm I think I am losing spark witch is causing my fuel to cut out......... and @ half throttle, this happens when my cams switch over. It's not my fuel, because I have set it at 40lbs all the way up to 65lbs.. Everything is wired right, and I believe I have the settings right.
Settings include:
Engine: 4 cyl.
Retard: off
Soft touch: off
Overrev: 8400 (I have tried to set this at a lower and a higher rpm just to test......same result)
NO CHIMERS!!!!!
Reply only if you have knowledge to back it up
thanks homies
later,
Old Apr 26, 2002 | 01:34 PM
Default Re: MSD Plus 6 problem (TypeR00_0371)
anybody home????
I've got to know soon!!!! T-N-T starts in 3 hours.....
later
Old Apr 27, 2002 | 04:12 PM
EleanoR's Avatar
From what i have heard the MSD ignition is not needed unless you are FI. A stock ignition system is perfectly fine. I would sell that MSD setup and look into other modifications. Just my .02
kuba_guzik110
Audio / Security / Video
Oct 5, 2013 12:47 AM
allhonda
Jul 14, 2007 09:27 AM
SmogTech01
May 20, 2007 12:33 PM
MyKey
Jun 7, 2004 07:48 PM
FastAllmotorLsVtec
Apr 16, 2004 07:01 PM
