Air-conditioning problem
Old Aug 23, 2006 | 11:24 AM
fongph's Avatar
* B A N N E D *
Default Air-conditioning problem
I have a 93 Civic Ex and I observed some weird things from my A/C. I don't think this is a freon problem because when it works, it is very cold. My problem is the A/C seems to toggle between working and non-working in cycles, like it will work for 10 minutes then it will stop working for 10 minutes and it will work again. I wonder if it is because of the compressor and the clutch inside quit working by spinning freely. When it works, the idle speed is 800 rpm which is normal but when it fails, the idle speed jumps to 1500 rpm which I think the compressor is not dragging on the engine (not spinning with the belt? or I don't know how it works...)
Please advice me where the problem is with my A/C system? Thanks a lot.
Old Aug 23, 2006 | 11:25 AM
Ricey McRicerton's Avatar
Default Re: Air-conditioning problem (fongph)
Not quite what you're looking for, but this was pretty helpful to me as far as troubleshooting the A/C.
https://honda-tech.com/zerothread/1729993
Old Aug 23, 2006 | 11:49 AM
sk8er5150's Avatar
I would just remove the power drainer
Old Aug 23, 2006 | 12:01 PM
Default Re: (sk8er5150)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8er5150 &raquo;</TD></TR><TR><TD CLASS="quote">I would just remove the power drainer</TD></TR></TABLE>
Gee thanks for your input. His question was how to FIX what he has, not how to give up, think like a 16 year old who just got a car and rip out one of the few nice creature comforts these econoboxes have in the first place.
Old Aug 23, 2006 | 12:25 PM
fongph's Avatar
* B A N N E D *
Default Re: Air-conditioning problem (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Not quite what you're looking for, but this was pretty helpful to me as far as troubleshooting the A/C.
https://honda-tech.com/zerothread/1729993</TD></TR></TABLE>
Thanks for the helpful info. But do you think it is my compressor? I didn't notice this problem in Fall or Winter until the summer which becomes very noticable even the A/C stops for 30 sec.
Old Aug 23, 2006 | 01:12 PM
alpine_hikr's Avatar
it sounds like your evaporator may be freezing up, then 10 minutes later after it heats up it begins working again. You could have a stuck open thermal expansion valve.
Old Aug 23, 2006 | 02:51 PM
fongph's Avatar
* B A N N E D *
Default Re: Air-conditioning problem (alpine_hikr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alpine_hikr &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like your evaporator may be freezing up, then 10 minutes later after it heats up it begins working again. You could have a stuck open thermal expansion valve.</TD></TR></TABLE>
Where is that part located? Can it be cleaned or I have to replace it?
Are you referring to part number #14? (link below)
http://www.slhondaparts.com/br...=true
Old Aug 24, 2006 | 08:07 PM
fongph's Avatar
* B A N N E D *
bump, still need an answer
blackcrx16
Jul 9, 2009 01:48 PM
si_em1
Oct 28, 2008 04:22 PM
tonezilla
Jul 30, 2005 04:41 AM
donger
Sep 18, 2004 05:58 AM
mechengine
Jun 5, 2004 09:04 PM
