Sensor on intake manifold? purge?
Old Aug 23, 2006 | 11:03 AM
StolenTeg's Avatar
Default Sensor on intake manifold? purge?
Where does the braided line (circle in red) goes to, the black box?(canister)
If i dont have a canister i block that line?
Old Aug 23, 2006 | 11:34 AM
DC2 Mang's Avatar
Default Re: Sensor on intake manifold? purge? (StolenTeg)
it should be going to the black evap canister ot else it is going to a vacuum source
the black sensor is part of the evap system, im not sure if it is the purge solenoid though
Old Aug 23, 2006 | 12:16 PM
StolenTeg's Avatar
Default Re: Sensor on intake manifold? purge? (DC2 Mang)
I believe it goes to the canister but not sure, if it goes to the canister which i remove, i need to plug it or put it to a vacuum source?
Old Aug 23, 2006 | 12:22 PM
DC2 Mang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">I believe it goes to the canister but not sure, if it goes to the canister which i remove, i need to plug it or put it to a vacuum source?</TD></TR></TABLE>
if you removed it then i dont think you have to plug the end with anything
Old Aug 23, 2006 | 04:16 PM
StolenTeg's Avatar
I start the car, it a vacuum( suck in). I plug it and the car run perfect, im thinking of just remove the sensor and put a bolt onto the hole
jdm_ek_noob
Jan 27, 2014 03:04 AM
ShagPower
15
Sep 2, 2006 08:28 AM
DJ Gurgla GSR
May 18, 2006 05:54 AM
Chase
22
Mar 21, 2005 02:59 PM
japspecjohn
15
Jun 9, 2004 10:38 AM
