Steering wheel twitches violentley :(
I all of the sudden got horrible vibration @ any speed and my steering wheel twitches violentley from side to side. I dont know if its the axle, mounts or wheel bearing. What would you think it is? I would post a video but I dont know how to upload avi. files.
does it do it on the gas and stop off the gas?
does it do it on the brakes?
does it do it at highway speeds?
what mph does it do it at and does it stop after a certain mph?
Typically, tires will make a car twitch if they need to be rotated/balanced or just replaced all together. If it does this when braking, you'll need to look at the rotors, they probably need regular maintenance. Or you could actually be unlucky enough to have issues with your axles or bearings, which would suck. I don't think a mount would be the problem, as it would be obvious if the mount was broken. They typically make loud cluttering sounds, especially after each shift, and usually a little power is lost to the wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turblow* »</TD></TR><TR><TD CLASS="quote">I found out what it was. It seems I had a huge ball on tire. It was swollen and it was only in one place. WTF ?</TD></TR></TABLE>
New tires time.
New tires time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turblow* »</TD></TR><TR><TD CLASS="quote"> It was swollen and it was only in one place. WTF ?</TD></TR></TABLE>
Tire seperation, very common. Get new ones before it blows out.
Toda Party
Oct 27, 2002 07:26 AM
