94 Civic Si Driveshaft
Old Aug 23, 2006 | 09:50 AM
defkid999's Avatar
Default 94 Civic Si Driveshaft
I went to do an oil change this morning in service and someone showed me that my half shaft on the driver front left side is loose (i can move it right and left when i mess with it) and needs to be replaced...the boot is torn in half also...
they quoted me for $136 for the axel and with labor like around $300. I was like screw that and i went online and ordered them for $78.74 with driver axel seal, boot, clamp, and axel assembly.
i was wondering if i could still drive my car for about another 4-7 days (thats when parts come in) without any problems...and is it easy to take out the driveshaft and put in the new one...
i have a 1994 civic si hatchback with ABS
Old Aug 23, 2006 | 09:54 AM
philosofy1's Avatar
Default Re: 94 Civic Si Driveshaft (defkid999)
when you say you paid online $78, that was for a rebuild kit or for an actual axle? it's easier just to pick up an axle at the part store for like $60. no the axle isn't hard to change, just eat your wheaties before starting.
and i personally couldn't tell you about the 4-7 days. that does sound like alot of play. if you had no choice, i guess it would be fine, just do the speed limit and no fast cornering or launches.
Old Aug 23, 2006 | 10:50 AM
instructor74's Avatar
Default Re: 94 Civic Si Driveshaft (philosofy1)
you should be okay. It is an easy job the hardest part can be getting the nut off the end of the shaft but other than that not bad at all.
Old Aug 23, 2006 | 10:56 AM
Stoich EG2's Avatar
if you were her in cali, i'd do it for $20 in 15 minutes rebuilt axles at autozone are only like $70 with a lifetime warranty.
Old Aug 23, 2006 | 01:08 PM
defkid999's Avatar
thanks for the replies everyone
heres the website to the axle assembly:
http://www2.hondiscountparts.c...=true
Old Aug 23, 2006 | 01:25 PM
-Gary-'s Avatar
Default Re: (defkid999)
What color is your car? I have a 1994 Si too.
Old Aug 23, 2006 | 01:41 PM
defkid999's Avatar
Default Re: (-Gary-)
Black Si
Old Aug 23, 2006 | 03:32 PM
Bense's Avatar
if you pull the axle, be sure to fill the trans up with HONDA MTF and if not honda MTF, use non-synthetic 10w-30
HovX
Sep 7, 2016 01:44 PM
tommy boy2
Dec 28, 2013 10:18 AM
Kid-jdm-teggy
Sep 14, 2013 02:36 PM
driveslow
19
Mar 5, 2009 07:03 PM
SFC
May 6, 2004 12:20 PM
