Can't Feel VTEC
My vtec Solenoid is leaking oil. I can't feel Vtec. Do you think this can be the problem?
Modified by Cyrus4g63 at 10:55 AM 8/23/2006
Modified by Cyrus4g63 at 10:57 AM 8/23/2006
Modified by Cyrus4g63 at 10:58 AM 8/23/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyrus4g63 »</TD></TR><TR><TD CLASS="quote">My V-Tech Solenoid is leaking oil. I can't feel Vtech. Do you think this can be the problem?</TD></TR></TABLE>
can't feel V-TECH huh! put your flame suit on.
it might be the problem, since you have a leak already might as well correct it. take the solenoid off to see where the leak is coming from.
Any kind of oil leak is pretty much a problem....check the solenoid make sure it's not clogged and replace the solenoid gasket....it would be wise to clean the solenoid.....
And just for the FYI just make sure it VTEC no V-TECH the phone manufacturer!
if you can feel vtec, your crossover point isnt set properly.
vtec should be a seamless switch between the high and low cam lobes, where the torque curves of each lobe intersect.
hearing vtec is another story however
i have a d16y8 and i can barly feel my VTEC...................... so maybe thats your problem................. single cam vtec. What engine do you have?
-hey man u got a Joint?
-uh no.......
-Id be a lot cooler if u did
hahaha....
I'm watching that movie right now!
"thats what i like about high school girls.
i get older, they stay the same age. yes they do, yes they do."
-wooderson
VTECH POWA!
-uh no.......
hahaha....
-wooderson
VTECH POWA!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgcrx »</TD></TR><TR><TD CLASS="quote">-hey man u got a Joint?
-uh no.......
hahaha....
-wooderson
VTECH POWA!</TD></TR></TABLE>
dazed and confused FTW
-uh no.......
hahaha....
-wooderson
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyrus4g63 »</TD></TR><TR><TD CLASS="quote">My vtec Solenoid is leaking oil. I can't feel Vtec. Do you think this can be the problem?</TD></TR></TABLE>
get rid of the single slammer
I doubt you will feel VTEC. but if it was not working you would get a Check engine light. If your car is stock you probably wont be able to hear it either.
Modified by LowSlow93Sol at 1:48 PM 8/23/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyrus4g63 »</TD></TR><TR><TD CLASS="quote">I have the B18C GSR.
I can hear it but I can' feel the power.</TD></TR></TABLE>
Is it your ECU tuned? When does Vtec kick in?
