What can i use to take off this Intake manifold gasket?!!
Old Aug 23, 2006 | 09:14 AM
J.nguyen's Avatar
Default What can i use to take off this Intake manifold gasket?!!
im tryin to switch intake manifolds and i took off the one intake manifold motor i baught from HMo and it was the paper gasket or wahtever and pieces stuck to the head. what can i use to make this process of removing this stuff easier??!!!
Old Aug 23, 2006 | 09:35 AM
Azn Kenny's Avatar
Those are a pain in the ***!
I sprayed some WD-40 on it and used a razor blade.
Old Aug 23, 2006 | 10:11 AM
J.nguyen's Avatar
Default Re: (Azn Kenny)
exactly what i did. but used some goo-gone too.hope that ddnt expletive it up..
Old Aug 23, 2006 | 10:16 AM
DC2 Mang's Avatar
Default Re: (Jesse.)
it will take alot of time, but use a razor blade and make sure to scrape it super clean so you wont get any vacuum leaks
Old Aug 23, 2006 | 10:19 AM
lVlemphizStylez's Avatar
Default Re: (DC2 Mang)
pray you dont chip the aluminum on the head, chip it too badly and youll get that vac leak
Old Aug 23, 2006 | 10:37 AM
RHDintegXsi's Avatar
Default Re: (lVlemphizStylez)
buy a can of "gasket remover" it comes in an aerosol can and works wonders. you would spray it on and let it soak in..what it does is soften it up really good to where you can scrape it off with a razor blade. you might have to repeat a couple times but it does make the task that much easier
Old Aug 23, 2006 | 10:39 AM
the_grinder's Avatar
Default Re: (SINFULintegXsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINFULintegXsi &raquo;</TD></TR><TR><TD CLASS="quote">buy a can of "gasket remover" it comes in an aerosol can and works wonders. you would spray it on and let it soak in..what it does is soften it up really good to where you can scrape it off with a razor blade. you might have to repeat a couple times but it does make the task that much easier</TD></TR></TABLE>
Best solution
Old Aug 23, 2006 | 11:38 AM
AwOrKiNpRoGrEsS23's Avatar
they also have gasket scrapers in different sizes at like all auto parts stores....it's like a blade on a handle...works good too
akdrag
11
Oct 5, 2009 07:14 PM
GsrVtec
Sep 13, 2006 09:53 AM
tinkerbell
Aug 26, 2002 10:53 PM
boot machine 5000
Jun 17, 2002 08:26 AM
91DA9
Jan 27, 2002 03:13 PM
