whats cause your a/c to not be cold
Old Aug 23, 2006 | 07:14 AM
Vt3c_eg's Avatar
Default whats cause your a/c to not be cold
like the title said what causes the a/c not to be cold. i recharge my a/c at the shop and its was working ok but it was not cold at all. see if i had 4 people in my car the a/c will never be cold. i check the measurement and its fine. i dont know what is causeing this problem. is it the clutch in the compressor or is it that the compressor is not working properly. it spins though,but now its not even cold. anybody know? it will help a lot!
Old Aug 23, 2006 | 07:22 AM
G2 Speed's Avatar
Default Re: whats cause your a/c to not be cold (Vt3c_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt3c_eg &raquo;</TD></TR><TR><TD CLASS="quote">like the title said what causes the a/c not to be cold. i recharge my a/c at the shop and its was working ok but it was not cold at all. see if i had 4 people in my car the a/c will never be cold. i check the measurement and its fine. i dont know what is causeing this problem. is it the clutch in the compressor or is it that the compressor is not working properly. it spins though,but now its not even cold. anybody know? it will help a lot!</TD></TR></TABLE>
4 - people generate alot of heat
Get a pressure washer and clean out the raidaitor
Old Aug 23, 2006 | 07:26 AM
Vt3c_eg's Avatar
Default Re: whats cause your a/c to not be cold (G2 Speed)
so you want me to wash the rad. and the compressor? are you sure.
Old Aug 23, 2006 | 07:28 AM
EG_Warped's Avatar
over time AC lines and what not leak down of freyon. I would first take it to a local shop and have them test to see if the proper amount of freyon is in the system. It could be a very small amount low and it wouldn't cool well.
Old Aug 23, 2006 | 07:31 AM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt3c_eg &raquo;</TD></TR><TR><TD CLASS="quote">so you want me to wash the rad. and the compressor? are you sure.</TD></TR></TABLE>
yea, spray it top to bottom.. all that dirt and crap can really stop a good flow
josh devera
Dec 25, 2016 10:27 AM
markusnjop
Jul 28, 2014 04:40 PM
purplemoon16
Apr 30, 2013 03:39 PM
jdm91CrxSi
10
Sep 25, 2007 11:00 AM
92integraVTECgsr
Sep 13, 2005 02:20 PM
