clutch issue its in and now not grabbing as it should
Old Aug 23, 2006 | 07:04 AM
conceptEG's Avatar
Default clutch issue its in and now not grabbing as it should
hey guys.. quick question.. i just put in a new oe clutch in my b18c.. its slipping now.. i mean i can still drive it but its not grabbing as it should..
i have the pedal adjusted all the way out under the pedal..and the clutch activates right when its almost all the way out...
if i adjust the pedal in towards the firewall..will that help the issue???
i mean this clutch is literally a day old..it shouldnt be doing this..
please help ideas needed
thanks
brian
Old Aug 23, 2006 | 07:47 AM
HONDA RR's Avatar
Default Re: clutch issue its in and now not grabbing as it should (hatr-aid)
Did you replace everything like the flywheel, pressure plate; release bearing with a new one?
Old Aug 23, 2006 | 09:12 AM
92DAIntegraXSI's Avatar
why would u have it adjusted all the way out? thats probably you problem you should have a inch of free play ( while depressing) then disengage .and it should engage about a inch or a little lower or higher depending on the way you like it from the floor. but you sholdnt have to lift the peadel totaly up to get the car to move.
97civicb20vtec
Transmission & Drivetrain
Aug 2, 2014 10:39 PM
MiNeSEK
19
May 11, 2013 12:05 AM
InitialJRift
Sep 13, 2006 10:43 AM
vteec
Oct 28, 2003 02:21 PM
