Are 94-97 GSR cluster different from 98-01 GSR cluster?
Old Aug 23, 2006 | 06:44 AM
traitorzxiong's Avatar
Default Are 94-97 GSR cluster different from 98-01 GSR cluster?
Just as the topic is stated in the title? Anything will help? Thanks
Old Aug 23, 2006 | 07:00 AM
ThatsTheTruth's Avatar
Default Re: Are 94-97 GSR cluster different from 98-01 GSR cluster? (traitorzxiong)
i think the the redlines are different, but im not sure. my 94 says 8k, but it looks like the 98+ have 8.5K. dont take my word for it
Old Aug 23, 2006 | 07:03 AM
DoctorGSR's Avatar
94-97 have a grey face, 98-01 have a black face.
the plugs in the back may be a little different also. i am not positive
Old Aug 23, 2006 | 07:12 AM
Will they plug and work correctly?
Old Aug 23, 2006 | 08:08 AM
Tonyl507's Avatar
bump, I need to know this also
Old Aug 23, 2006 | 08:13 AM
gogogomoveit's Avatar
Default Re: Are 94-97 GSR cluster different from 98-01 GSR cluster? (ThatsTheTruth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsTheTruth &raquo;</TD></TR><TR><TD CLASS="quote">i think the the redlines are different, but im not sure. my 94 says 8k, but it looks like the 98+ have 8.5K. dont take my word for it </TD></TR></TABLE>
Dont think so. Newer engines doesnt rev any higher. You might have looked at a ITR cluster.
Old Aug 23, 2006 | 08:20 AM
be.twenty's Avatar
Default Re: Are 94-97 GSR cluster different from 98-01 GSR cluster? (gogogomoveit)
cosmetic changes are minimal..
the big thing is the green paper film thing at the back of the cluster, you'll need to swap those for it to work
Old Aug 23, 2006 | 08:23 AM
SFSETEG's Avatar
94-95 is OBD1 the plug is and OBD2 plug after 95 so you would need to slice the plug and wire a new connector
Old Aug 23, 2006 | 08:24 AM
be.twenty's Avatar
Default Re: (SFSETEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFSETEG &raquo;</TD></TR><TR><TD CLASS="quote">94-95 is OBD1 the plug is and OBD2 plug after 95 so you would need to slice the plug and wire a new connector</TD></TR></TABLE>
not necessary..
Old Aug 23, 2006 | 09:13 AM
Ok guys what is the deal here. Who's sure and who not?
Old Aug 23, 2006 | 09:31 AM
be.twenty's Avatar
i'm 100% sure. i've swapped many clusters from all years ..
Old Aug 23, 2006 | 09:39 AM
Default Re: (Nuck Chorris)
So all you need to do is swap the green paper on the back for it to work?
Old Aug 23, 2006 | 10:40 AM
95dc2teg's Avatar
Default Re: (traitorzxiong)
I would like to know this too because if the new gauges are black faced then that would be sweet!
Old Aug 23, 2006 | 10:51 AM
be.twenty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traitorzxiong &raquo;</TD></TR><TR><TD CLASS="quote">So all you need to do is swap the green paper on the back for it to work?</TD></TR></TABLE>
yes... or, physically move each gauge over from the new housing..... but the green paper is easier. but don't rip or bend it... or you'll be SOL
Old Aug 23, 2006 | 05:18 PM
Thanks for the infomation.
Old Aug 23, 2006 | 05:34 PM
trick_db's Avatar
i swapped cluster before, 95-97 gsr cluster is grey face, 98+ is black face, 98 look more cleaner, redline is the same and all that
when you change it, you can change the green film... the plug are the same, is not different, dont listen to them.
Joeyt426
Jul 22, 2006 03:48 PM
crxsimike
Dec 31, 2005 10:17 AM
D21X
Jun 15, 2005 03:28 AM
darrinbrewer
Feb 26, 2005 03:01 PM
Black Raven
Sep 6, 2004 10:43 PM
