D16A6 Chip- Good or Bad???????
I bought a chip from AFM performance, yes AFM, it set rev limit to 8,500 and does my ignition and fuel to match that high is this ok on D16A6 anyone rev that high on D16?
umm... That high on a d16a6!?!?! you'd better hope that that engine's not stock!!!! The stock redline IS 6500 by the way! that's 2000 rpm above the safe RPM for the rods, valvesprings, etc! You'd better build that motor to take the abuse! Stock D16's are not know for their strength at high RPM (just look at the ZC's rep). Rev that high on a stock motor and watch a piston fly out of your hood.
I use the 90-91 pm6 ecu chipped with a gsr program. And it works better than My old pr3 ecu. I ran 14.72 with the pr3 and then I switch up and ran a 14.60 with the chipped pm6. But here is the catch you need to use a msd activator to activate the vtec. I set it at 5000rpm's
just because it says 8 500 rpm rev limit doesnt mean to go there. There is no rev limit on my PM6 but I only take it up to 8000rpm. its prepped for that high of rpms.. complete upgraded valvetrain.. retainers, valvesprings, etc.
Wil
Wil
Wil
Wil
Ok only take it that high if its preped.
Now where do i find spring and valve upgrades. i looked and did not find. Who makes it? PS thanks for the advise.
TypeR 01 886
Jul 30, 2003 03:10 AM
SohcVtecCrix
Nov 19, 2002 01:12 PM
Acura_I-RS
Mar 1, 2002 05:00 PM
dont do it
