90 crx si gsr swap
Old Aug 22, 2006 | 08:13 PM
nomotor's Avatar
Default 90 crx si gsr swap
currently i have an LS swap(cable) in my crx. can i just drop the gsr motor and tranny in there with hasport mounts or do i need to switch up the axles again? also i have the ecu and obd1 jumper harness, do i need anything else?
Old Aug 24, 2006 | 12:44 AM
T
Default Re: 90 crx si gsr swap (nomotor)
u need the cable to hydro conversion kit and your axles should be fine.
Old Aug 24, 2006 | 06:46 AM
nomotor's Avatar
Default Re: 90 crx si gsr swap (T"u"Rtle)
alrite thanks
Old Aug 25, 2006 | 01:32 AM
HondaPartsHero's Avatar
Technical Hero
you'll need a bit of wiring from the VTEC/Knock related sensors from the sensor itself to the ECU and a Distributor adaptor
Riptide101
May 8, 2018 11:56 AM
ricardo13d
Jun 2, 2009 12:21 PM
dochzc
Nov 9, 2004 12:14 PM
xjun10rx
Apr 28, 2004 02:51 PM
B18C1_CRX
May 12, 2003 01:09 PM
