AC compressor won't turn on
I just bought a prelude and one of the many small problems on the car is the AC compressor will not come on. There is a problem with the HVAC unit because sometimes none of the lights turn on but if I hit the dash (solves all) both the lights and the AC light comes on. However, the actual AC compressor will not activate. The wire from the AC unit to the harness is connected properly.
What should I do?
What should I do?
what year prelude. if its not r134a, get it vacculated and recharged. if it is r134a, grab a gauge from walmart and hook it up and see if you are low on pressure. If so get a can of r134a and add it.
Bring it to a shop, that R12 **** is nasty for the air, yes a low pressure will trip your compressor off so it doesnt damage itself. A shop will do a vaccum test and repair any leaks then replace the R12 with R134.
boredazhell20
Sep 22, 2010 01:02 PM
jaredvabeach
Aug 2, 2009 06:17 PM
