timing belt slack
k i just changed my timing belt and when i started the car, i hear lotsa slapping and the timing belt is hella wobly like its going to slip off the cam gears.
so i tryin to redo the belt install, a couple questions here: 1. which one is the exhaust cam and intake cam? and 2. is there any tips on trying to get the belt on cuz its a real bitch to put on?
yea i following haynes manual and teamintegra.net directions they say put in this odor : 1. crankshaft poopie 2. bitch *** tensioner 3. gay water pump 4. exhaust fart cam 5. intake shmintake cam but when i get to the intake cam its ****** to get it in the gear so i push the tensioner down wit a philips to gimme some slack, but it so daym much tight i can't fit around the intake cam gear
It is impossible to mix up the intake and exhaust cam.
Your problem is that you aren't tensioning it correctly. First, you need to loosen the tensioner bolt 180 degrees. Once the belt is set correctly on the cams, you need to crank it counterclockwise three teeth and then tighten the tensioner back up to 40 ft/lbs. Rotate it a few times to make sure there isn't excessive slack and check that the timing is still good. If it all checks out, you are good to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style »</TD></TR><TR><TD CLASS="quote">It is impossible to mix up the intake and exhaust cam.
Your problem is that you aren't tensioning it correctly. First, you need to loosen the tensioner bolt 180 degrees. Once the belt is set correctly on the cams, you need to crank it counterclockwise three teeth and then tighten the tensioner back up to 40 ft/lbs. Rotate it a few times to make sure there isn't excessive slack and check that the timing is still good. If it all checks out, you are good to go.</TD></TR></TABLE>
this does not always work...sometimes the tensioner will not pull up properly...thats when you get a long screw driver and pry up on the tensioner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez »</TD></TR><TR><TD CLASS="quote">
this does not always work...sometimes the tensioner will not pull up properly...thats when you get a long screw driver and pry up on the tensioner</TD></TR></TABLE>
Possible. Assuming he just replaced the tensioner, I don't think that would be a problem.
92EG8
Nov 2, 2008 03:41 AM
