driver side wheel play when jacked up...
Old Aug 22, 2006 | 03:39 PM
Dwight Schrute's Avatar
Default driver side wheel play when jacked up...
i was replacing my ball joint boot on my 92 civic dx today. i was also checking to see what else needed replacing. i recently replace my steering rack with one from a 94 integra with 113k miles because my old one needed a full rebuild and it was recommended i just replace it. everything is good with that except i might need to replace the outer tie rods soon since one got a pinhole in the boot and the drivers side one is a little more loose than the pass side.
anyways, when i grab the wheel at 8 o clock and 3 o clock and shake it side to side, there seems to be a lot of play. it's not coming from the tie rod. it's coming from the actual hub. now, i was thinking wheel bearing, but wouldn't that be loud when i drive? i just did a 300mi round trip at 80-90mph and it was smooth as hell. when i replaced my ball joints, i had to remove the dust cover for the bearing , but i know i put it back on right. could it be the cv joint?
Old Aug 22, 2006 | 03:48 PM
beoy9's Avatar
Default Re: driver side wheel play when jacked up... (drewthomas14)
I recently had the same issue, mine didn't make a lot of noise, but it did ding when I'd hit any kind of bump. At first it was hardly noticable, but it got louder and louder untill I had it replaced. No more noise, no more play
Old Aug 23, 2006 | 08:08 AM
Default Re: driver side wheel play when jacked up... (beoy9)
mine doesnt make any noise at all. could it be anything else?
Old Aug 23, 2006 | 09:00 AM
beoy9's Avatar
Could be, mine didn't make noise at first. It eventually started to and got louder and louder.
Old Aug 23, 2006 | 09:10 AM
Syndacate's Avatar
Could be a tie rod end. Free play in the wheel is usually because of that.
Old Aug 23, 2006 | 09:13 AM
SiCRX90's Avatar
Default Re: (Syndacate)
does your car jump around when you turn corners? if so, its the wheel bearings...if not, check the tie rod ends
BigRonDawg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewthomas14 &raquo;</TD></TR><TR><TD CLASS="quote">anyways, when i grab the wheel at 8 o clock and 3 o clock and shake it side to side, there seems to be a lot of play. it's not coming from the tie rod. it's coming from the actual hub. now, i was thinking wheel bearing, but wouldn't that be loud when i drive? i just did a 300mi round trip at 80-90mph and it was smooth as hell. when i replaced my ball joints, i had to remove the dust cover for the bearing , but i know i put it back on right. could it be the cv joint? </TD></TR></TABLE>
Old Aug 23, 2006 | 09:18 AM
philosofy1's Avatar
i have the same problem, i grabbed the wheel the other day (while jacked up), and i had some play too. it does seem to be from the hub. looked around as i was shaking it to see if it was my ball joints, but they seem fine. i was guessing to if it was the axles.
mine makes almost like a choppy noise (like a helicpoter in the distance). especially where the road bends.
Old Aug 23, 2006 | 12:43 PM
Default Re: driver side wheel play when jacked up... (philosofy1)
i just replaced my lower ball joints, so i know it's not that. im just wondering if a bad cv joint would cause this. im replacing my tranny soon , so i could just get new ones when i do that.
Old Aug 26, 2006 | 11:19 AM
Old Aug 26, 2006 | 11:21 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewthomas14 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
so is it your axle?
Old Aug 26, 2006 | 12:02 PM
i have no idea, i was just bumping it.
Old Aug 26, 2006 | 12:04 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewthomas14 &raquo;</TD></TR><TR><TD CLASS="quote">i have no idea, i was just bumping it. </TD></TR></TABLE>
Dragon219
May 31, 2013 08:35 PM
jonyi27
Dec 9, 2012 10:55 AM
boost4life1
Nov 17, 2011 02:53 PM
AllSpedup04
Aug 3, 2004 10:13 AM
