Head plug cause Head Gasket failure???!?!?!....
Old Aug 22, 2006 | 02:44 PM
Tuesday Club's Avatar
Default Head plug cause Head Gasket failure???!?!?!....
A friend put a motor together for me a month ago, and needless to say, the plug required for an LS/V was left in the head at the folly of my friend. I am currently experiencing no idle, white smoke out of the VC breather/ dipstick/ exhaust. I am DD'ing this car, and need to know if the likely suspect is a blown HG because of the plug.
Engine:
B16 (1st gen) Head
Built ( Valvetrain, cams, etc.)
Stock B16 block....
I have the time this weekend to pull the head and replace the gasket/remove the plug, but I would like to confirm my fears before I invest time/$ into this motor. ( i have spares, so down time is negligable)
Old Aug 22, 2006 | 03:01 PM
philosofy1's Avatar
Default Re: Head plug cause Head Gasket failure???!?!?!.... (Tuesday Club)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tuesday Club &raquo;</TD></TR><TR><TD CLASS="quote">
Engine:
B16 (1st gen) Head
Stock B16 block....
the plug for the ls/v? you mean the oil kit for the ls/vtec? why would you need a plug on a stock b16 block?
Old Aug 22, 2006 | 03:47 PM
Rock Meathammer's Avatar
Default Re: Head plug cause Head Gasket failure???!?!?!.... (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
the plug for the ls/v? you mean the oil kit for the ls/vtec? why would you need a plug on a stock b16 block?</TD></TR></TABLE>
I think the head was from a previous ls/v setup, and it was left in the head. OP wouldn't have vtec if there was no oil going to it correct? Just do what you plan on doing over the weekend. Sounds like your on the right path. HG sounds blown to me.
Old Aug 22, 2006 | 07:17 PM
Default Re: Head plug cause Head Gasket failure???!?!?!.... (B20 EJ6)
no vtec..... I know this already (not a prob.)
The plug from a previous LSV kit is still in....I just want to make sure (90%) that the head gasket is most likely blown, and that it would cause the smoking problem.
Thank you for the posts
Old Aug 22, 2006 | 11:31 PM
bump for a hypothesis
Old Aug 23, 2006 | 07:33 AM
bump for not another CAI question
Old Aug 23, 2006 | 08:37 AM
NJcoupe's Avatar
bump for a real question; even i'd like to see the answer from.
Old Aug 23, 2006 | 10:40 AM
Default Re: Head plug cause Head Gasket failure???!?!?!.... (dxcoupe.)
thank you
Old Aug 23, 2006 | 01:55 PM
uno tiempo mas
Wonderboy93
Dec 22, 2016 07:06 AM
NIKADEM0
Sep 19, 2013 07:05 PM
CRXguy_88
Jul 14, 2011 01:40 PM
da1haloking
Apr 22, 2009 05:03 PM
Tuesday Club
23
Aug 24, 2006 04:41 PM
