Car won't go in reverse ?
Old Aug 22, 2006 | 01:40 PM
HCJDM1's Avatar
Default Car won't go in reverse ?
i just got my 94 civic a few months ago ... it runs real nice except for every so often ..it wont go in reverse ...
i did some seaches and found out that if i come to a stop .. and go into reverse ... theres a stop point so the grears stop spinning .. a wait a while and still it doesnt go into reverse...
around the or fourth try it goes .. (its a manual stock transmission )
anyone know whats wrong ?
thanks
Old Aug 22, 2006 | 01:42 PM
philosofy1's Avatar
Default Re: Car won't go in reverse ? (HCJDM1)
my sister 95 ex(d16) used to do this. there is a trick, put the shifter into 1st, 2nd, then reverse. i bet anything it'll work. if not then you have bigger problems.
Old Aug 22, 2006 | 01:48 PM
slammedEM1Si's Avatar
sounds like the clutch is shot
Old Aug 22, 2006 | 01:59 PM
HCJDM1's Avatar
Default Re: (slammedEM1Si)
no i dont think the clutch is shot ... because sometime it goes into reverse perfectly ... and other times it wont ...
and every so often, its rare its only happened 3 times ... it feels rough going into 1st and second and sometimes it doesnt go .. i usually have to put it in neautral and then back in to first and its fine
Old Aug 22, 2006 | 02:01 PM
Froth's Avatar
Default Re: (HCJDM1)
Sounds like your syncro's might be going on 1st/2nd, reverse is just hard sometimes...i just throw it in 4th and then reverse. Goes every time.
Old Aug 22, 2006 | 02:03 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCJDM1 &raquo;</TD></TR><TR><TD CLASS="quote">no i dont think the clutch is shot ... because sometime it goes into reverse perfectly ... and other times it wont ...
and every so often, its rare its only happened 3 times ... it feels rough going into 1st and second and sometimes it doesnt go .. i usually have to put it in neautral and then back in to first and its fine </TD></TR></TABLE>
yeah, your syncros might be going out. just try the what we posted and post back with results.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">my sister 95 ex(d16) used to do this. there is a trick, put the shifter into 1st, 2nd, then reverse. i bet anything it'll work. if not then you have bigger problems.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Froth &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like your syncro's might be going on 1st/2nd, reverse is just hard sometimes...i just throw it in 4th and then reverse. Goes every time.</TD></TR></TABLE>
CHEFH22HATCH's Avatar
HONDA = FIRST GEAR THEN IT SLIDES RIGHT INTO REVERSE
Old Aug 22, 2006 | 02:04 PM
cambopheonix56's Avatar
Default Re: (philosofy1)
Put it in any gear, it will go in.
Old Aug 22, 2006 | 02:11 PM
savinGAShaulinAss's Avatar
Default Re: (cambopheonix56)
c'mon buddy i thought you would've known by now u can just put it in you have to play with it a little then it'll slide right in
Old Aug 22, 2006 | 02:14 PM
philosofy1's Avatar
Default Re: (savinGAShaulinAss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by savinGAShaulinAss &raquo;</TD></TR><TR><TD CLASS="quote">c'mon buddy i thought you would've known by now u can just put it in you have to play with it a little then it'll slide right in </TD></TR></TABLE>
LOL!, i guess it's his first time.
Old Aug 22, 2006 | 03:40 PM
nutball72's Avatar
try putting it in rev, as far as it will go, then let off the clutch a little (right before it catches) while pushing the shifter towards rev, and she should slide right in!
Old Aug 22, 2006 | 07:32 PM
HCJDM1's Avatar
Default Re: Car won't go in reverse ? (philosofy1)
1st to 2nd and then reverse worked ! then i didnt have that problem the whole day .
hope it doesnt act up to much tomarrow
because it useually takes alot more than that ..
Old Aug 22, 2006 | 07:35 PM
Syndacate's Avatar
Agreed, 'cept use 4th, it'll go in easier and slow the shaft faster.
It's because there's no syncros in reverse - there's nothing wrong with your car.
Old Aug 23, 2006 | 08:50 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCJDM1 &raquo;</TD></TR><TR><TD CLASS="quote">1st to 2nd and then reverse worked ! then i didnt have that problem the whole day .
because it useually takes alot more than that .. </TD></TR></TABLE>
told you, you should be fine!
Old Aug 23, 2006 | 08:59 AM
HCJDM1's Avatar
cool ... thanks
Old Aug 23, 2006 | 09:01 AM
Syndacate's Avatar
told you, you should be fine! </TD></TR></TABLE>
I'm tryin to say this w/o being a dick to philsofy b/c I know he knows what he's talking about but I Have an easier way :-P.
Just put the car in 4th gear, then it'll go into reverse real easy - promise.
Only reason I say that instead of 1st, 2nd, R, is because 4th, R is easier, it'll slide into 4th easier (obviously) and R is right next door &gt;.&lt;.
Try it Philosofy, I'm tellin ya it works :-P - I dunno, maybe it's just me, but it's easier than 1st, 2nd, R, just lsap it into 4th, then right into reverse.
BTW: HERE'S ANOTHER WAY
Yeah, I'm serious here....Aight, here's what ya do, put it in reverse until it "stops." THen keep pulling down with light pressure and release the clutch slowly, when the clutch is about half way up - before any gears start to grind, before you pop the clutch, before any of that, the stick'll slide right into reverse - I **** you not. I don't know why it does it and I don't care to find out...it's by far the best way IMO - better than the first way I stated. In my personal opinion it's better than th eway philosofy stated also.. If you dont' believe me try it...when your car won't go into reverse just pull LIGHT pressure towards reverse (stick shouldn't go anywhere) - don't force it down in there so the gears grind...just as u would shift, lightly....and then pull the clutch out (SLOWLY!) - it'll slide right into reverse, you're right next to the clutch grab point, give it some gas, and go for it....backwards...
Definately serious, try it, both of you, hella lot easier.
Old Aug 23, 2006 | 09:06 AM
HCJDM1's Avatar
Default Re: Car won't go in reverse ? (Syndacate)
ok ill try the both ... see whats works better ... and post the results ...
Old Aug 23, 2006 | 09:13 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
Definately serious, try it, both of you, hella lot easier.</TD></TR></TABLE>
i don't have the same problem as HCJDM1, thank god (no offense), but if i do i will keep it in mind!
93delslow315
Feb 5, 2010 07:08 AM
Niskyspy
Sep 5, 2007 06:23 PM
Miz101
May 15, 2005 06:11 AM
Lo-Buck EF
Apr 28, 2003 06:56 PM
