S2000 CLUSTER SPEEDO AND TACH IN EG HOW TO (VOLTAGE CONVERTER)
Old Aug 22, 2006 | 12:30 PM
jdmturbosol's Avatar
Default AFTERMARKET SPEEDO AND TACH IN EG HOW TO (VOLTAGE CONVERTER)
http://www.dakotadigital.com/i...7.htm
THIS IS WAY CHEAPER THAN THE OTHER SPEEDOMETER AND TACH CONVERTERS OUT THERE
YOUR WELCOME IN ADVANCE
Modified by jdmturbosol at 4:12 PM 9/19/2006
Old Aug 23, 2006 | 05:58 AM
EE_Chris's Avatar
Default Re: S2000 CLUSTER SPEEDO AND TACH IN EG HOW TO (jdmturbosol)
Well, the price is right. I've seen others go for almost double.
What's up with the poll options though?
Old Aug 23, 2006 | 02:30 PM
Default Re: S2000 CLUSTER SPEEDO AND TACH IN EG HOW TO (EE_Chris)
The tach converter works awesome
the speedo converter should work also
it looks to have alot of adjustment
sorry about the polls
I dont know how to get rid of it?
just put a rc51 cluster in a civic and its pretty dope!
Modified by jdmturbosol at 8:12 PM 8/23/2006
Old Aug 29, 2006 | 09:25 AM
wEaK Squad *ATL*'s Avatar
^ what the hell is that..... more pics ^
Old Sep 5, 2006 | 10:38 PM
Kidnkorner's Avatar
Default Re: S2000 CLUSTER SPEEDO AND TACH IN EG HOW TO (wEaK Squad)
that looks like an S2000 cluster integrated with the civics stock temp and fuel guage.......nasty!
Old Sep 6, 2006 | 08:28 PM
runsfromdacops's Avatar
Default Re: S2000 CLUSTER SPEEDO AND TACH IN EG HOW TO (Lynx Bus Type R)
its a bike cluster and its form a pimp *** bike!!
Old Sep 7, 2006 | 07:48 PM
jdmsiR20's Avatar
Default Re: S2000 CLUSTER SPEEDO AND TACH IN EG HOW TO (runsfromdacops)
friggin gangsta
it'd be kool if u could get more shots up
Old Sep 15, 2006 | 02:20 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
I wouldn't call this a HOW TO, it's simply a link to something that may or may not work. This converts the VSS signal from the tranny into the correct format on the S2K cluster? Does it work with K series swapped cars? We need more info.
Bigcalidave will likely chime in and let us know whats up.
Old Sep 16, 2006 | 08:08 PM
ildknyli's Avatar
Default Re: S2000 CLUSTER SPEEDO AND TACH IN EG HOW TO (NAallTheWAY)
Could you use this and the s2000 guage cluster in a 2001 prelude?
Old Sep 18, 2006 | 02:43 PM
bigcalidave's Avatar
Please do research before telling people it is the "correct" way to do it. Before I developed the converter that worked, I spoke with the designers of EVERY COMMERCIAL SPEED CONVERTER. None of them would work to the speeds required by the s2k cluster. In typical HT fashion, someone who did no research at all has posted something like this. Don't even know why you would bother!
Anyways, please don't waste your money, or if you do, please post on here that you did so that others don't make your mistake!
Thanks!
Old Sep 18, 2006 | 10:52 PM
You also have no need for a tach converter with the s2000 cluster. Works just fine with your stock tach signal.
Old Sep 19, 2006 | 12:14 PM
Default Re: (bigcalidave)
I DIDNT USE A S2000 CLUSTER SO IM NOT SURE IF IT WORKS ON CERTAIN APPLICATIONS
I KNOW IT WORKS FOR THE RC51 CLUSTER
Old Sep 20, 2006 | 08:41 AM
Real_E-AT's Avatar
Default Re: (jdmturbosol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmturbosol &raquo;</TD></TR><TR><TD CLASS="quote">I DIDNT USE A S2000 CLUSTER SO IM NOT SURE IF IT WORKS ON CERTAIN APPLICATIONS
I KNOW IT WORKS FOR THE RC51 CLUSTER</TD></TR></TABLE>CALM DOWN!!!!
Old Sep 27, 2006 | 11:27 AM
cjames235's Avatar
lol youre the one who titled it s2000 cluster in EG......... btw that rc51 cluster is PIMPTASTIC!!!
Old Sep 27, 2006 | 12:42 PM
dpaton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmturbosol &raquo;</TD></TR><TR><TD CLASS="quote">I DIDNT USE A S2000 CLUSTER SO IM NOT SURE IF IT WORKS ON CERTAIN APPLICATIONS</TD></TR></TABLE>
2 things:
1. Lay off the caps. No one likes yelling.
2. If you've never tried it with an S2K cluster WTF are you doing titling the thread "S2000 CLUSTER...IN EG HOW TO"? Seriously.
Old Oct 16, 2006 | 06:08 AM
Default Re: (dpaton)
I work parts and all my part numbers are caps so my computer is always on caps
If I was yelling I would have put !!!!
Old Oct 16, 2006 | 02:04 PM
dpaton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmturbosol &raquo;</TD></TR><TR><TD CLASS="quote">I work parts and all my part numbers are caps so my computer is always on caps
If I was yelling I would have put !!!!</TD></TR></TABLE>
Lazyness &gt; you.
It takes longer to type in the H-T URL than it does to hit the caps lock key. Come on...
Thanks for changing the thread title. Accuracy
Old Oct 18, 2006 | 02:24 PM
kevmugen's Avatar
that looks gay
peterJDM
Mar 26, 2018 12:40 AM
untuned
Jan 27, 2008 01:06 PM
Ktuned2007
Jul 8, 2007 10:13 PM
maxpierre
Honda S2000
13
Dec 11, 2006 09:14 PM
djmatix
Mar 27, 2006 10:46 AM
